REST API reference
Retrieve export policies
Retrieves export policies to view the current configurations for exporting file systems to clients. This information helps you manage and adjust access settings for network file sharing.
HTTP method and endpoint
GET /protocols/nfs/export-policies
Introduced in
ONTAP 9.6
  • vserver export-policy show
  • vserver export-policy rule show
id
integer
query
False
Filter by id
name
string
query
False
Filter by name
rules.superuser
string
query
False
Filter by rules.superuser
rules.allow_device_creation
boolean
query
False
Filter by rules.allow_device_creation
  • Introduced in: 9.9
rules.ro_rule
string
query
False
Filter by rules.ro_rule
rules.ntfs_unix_security
string
query
False
Filter by rules.ntfs_unix_security
rules.clients.match
string
query
False
Filter by rules.clients.match
rules.allow_suid
boolean
query
False
Filter by rules.allow_suid
rules.protocols
string
query
False
Filter by rules.protocols
rules.chown_mode
string
query
False
Filter by rules.chown_mode
rules.anonymous_user
string
query
False
Filter by rules.anonymous_user
rules.index
integer
query
False
Filter by rules.index
rules.rw_rule
string
query
False
Filter by rules.rw_rule
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of export policy records
records
array[export_policy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "id": 0,
      "name": "string",
      "rules": [
          "anonymous_user": "string",
          "chown_mode": "string",
          "clients": [
              "match": "0.0.0.0/0"
          "ntfs_unix_security": "string",
          "protocols": [
            "string"
          "ro_rule": [
            "string"
          "rw_rule": [
            "string"
          "superuser": [
            "string"
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rules
_links
_links
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
_links
_links
name
string
The name of the SVM.
uuid
string
export_policy
_links
_links
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rules]
Rules of the Export Policy.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
