Retrieve export policies
Retrieves export policies to access and review the rules governing data export from the storage system. This helps ensure that data sharing across different client systems adheres to established security and access protocols.
HTTP method and endpoint
GET /protocols/nfs/export-policies
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver export-policy show -
vserver export-policy rule show
Learn more
rules.index |
integer |
query |
False |
Filter by rules.index |
rules.superuser |
string |
query |
False |
Filter by rules.superuser |
rules.chown_mode |
string |
query |
False |
Filter by rules.chown_mode
rules.allow_device_creation |
boolean |
query |
False |
Filter by rules.allow_device_creation
rules.ntfs_unix_security |
string |
query |
False |
Filter by rules.ntfs_unix_security
rules.rw_rule |
string |
query |
False |
Filter by rules.rw_rule |
rules.ro_rule |
string |
query |
False |
Filter by rules.ro_rule |
rules.allow_suid |
boolean |
query |
False |
Filter by rules.allow_suid
rules.clients.match |
string |
query |
False |
Filter by rules.clients.match |
rules.anonymous_user |
string |
query |
False |
Filter by rules.anonymous_user |
rules.protocols |
string |
query |
False |
Filter by rules.protocols |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
name |
string |
query |
False |
Filter by name
id |
integer |
query |
False |
Filter by id |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of export policy records |
records |
array[export_policy] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"id": 0,
"name": "string",
"rules": [
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"ntfs_unix_security": "string",
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
export_rules
_links |
boolean |
Specifies whether or not device creation is allowed. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
string |
NTFS export UNIX security options. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm
_links |
name |
string |
uuid |
string |
export_policy
_links |
id |
integer |
Export Policy ID |
name |
string |
Export Policy Name |
rules |
array[export_rules] |
Rules of the Export Policy. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
