REST API reference
Retrieve export policies
Retrieves export policies to view the current configurations for exporting file systems. This helps you manage access permissions and settings for clients accessing your networked storage.
HTTP method and endpoint
GET /protocols/nfs/export-policies
Introduced in
ONTAP 9.6
  • vserver export-policy show
  • vserver export-policy rule show
rules.allow_device_creation
boolean
query
False
Filter by rules.allow_device_creation
  • Introduced in: 9.9
rules.chown_mode
string
query
False
Filter by rules.chown_mode
rules.index
integer
query
False
Filter by rules.index
rules.superuser
string
query
False
Filter by rules.superuser
rules.rw_rule
string
query
False
Filter by rules.rw_rule
rules.clients.match
string
query
False
Filter by rules.clients.match
rules.anonymous_user
string
query
False
Filter by rules.anonymous_user
rules.protocols
string
query
False
Filter by rules.protocols
rules.ro_rule
string
query
False
Filter by rules.ro_rule
rules.ntfs_unix_security
string
query
False
Filter by rules.ntfs_unix_security
rules.allow_suid
boolean
query
False
Filter by rules.allow_suid
name
string
query
False
Filter by name
  • maxLength: 256
id
integer
query
False
Filter by id
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of export policy records
records
array[export_policy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "id": 0,
      "name": "string",
      "rules": [
          "anonymous_user": "string",
          "chown_mode": "string",
          "clients": [
              "match": "0.0.0.0/0"
          "ntfs_unix_security": "string",
          "protocols": [
            "string"
          "ro_rule": [
            "string"
          "rw_rule": [
            "string"
          "superuser": [
            "string"
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
262197
The value provided is invalid for the field
2621462
The specified SVM name does not exist
2621519
SVM name is invalid. The SVM name must begin with a letter or an underscore. If the SVM is of type "sync-source", the maximum supported length is 41. Otherwise, the maximum supported length is 47
2621643
The specified SVM name is too long
2621685
SVM name length cannot be zero
2621706
The specified SVM UUID is incorrect for the specified SVM name
6691623
User is not authorized
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rules
_links
_links
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
_links
_links
name
string
uuid
string
export_policy
_links
_links
id
integer
Export Policy ID
name
string
Export Policy Name
rules
array[export_rules]
Rules of the Export Policy.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
