Retrieve export policies
GET /protocols/nfs/export-policies
Introduced In: 9.6
Retrieves export policies.
Related ONTAP commands
vserver export-policy show -
vserver export-policy rule show
Learn more
rules.ntfs_unix_security |
string |
query |
False |
Filter by rules.ntfs_unix_security
rules.ro_rule |
string |
query |
False |
Filter by rules.ro_rule |
rules.superuser |
string |
query |
False |
Filter by rules.superuser |
rules.protocols |
string |
query |
False |
Filter by rules.protocols |
rules.allow_suid |
boolean |
query |
False |
Filter by rules.allow_suid
rules.rw_rule |
string |
query |
False |
Filter by rules.rw_rule |
rules.allow_device_creation |
boolean |
query |
False |
Filter by rules.allow_device_creation
rules.index |
integer |
query |
False |
Filter by rules.index |
rules.clients.match |
string |
query |
False |
Filter by rules.clients.match |
rules.chown_mode |
string |
query |
False |
Filter by rules.chown_mode
rules.anonymous_user |
string |
query |
False |
Filter by rules.anonymous_user |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
id |
integer |
query |
False |
Filter by id |
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of export policy records |
records |
array[export_policy] |
"next": {
"href": "/api/resourcelink"
"records": [
"id": 0,
"name": "string",
"rules": [
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"index": 0,
"ntfs_unix_security": "string",
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
export_client
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
export_rule
_links |
boolean |
Specifies whether or not device creation is allowed. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_client] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
string |
NTFS export UNIX security options. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
export_policy
_links |
id |
integer |
Export Policy ID |
name |
string |
Export Policy Name |
rules |
array[export_rule] |
Rules of the Export Policy. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
