Retrieve export policies
Retrieves export policies to review and manage the rules governing access to your network resources. Use this operation to ensure your export policies align with your data access requirements.
HTTP method and endpoint
GET /protocols/nfs/export-policies
Introduced in
ONTAP 9.6
Related ONTAP commands
vserver export-policy show -
vserver export-policy rule show
Learn more
are_rules_truncated is set to 'true' if the total number of export-policy rules is greater than 500. If set to 'true', rules after 500 will be truncated. Use GET /api/protocols/nfs/export-policies/{id}/rules to retrieve all rules for truncated policies.
rules.superuser |
string |
query |
False |
Filter by rules.superuser |
rules.chown_mode |
string |
query |
False |
Filter by rules.chown_mode
rules.ntfs_unix_security |
string |
query |
False |
Filter by rules.ntfs_unix_security
rules.allow_device_creation |
boolean |
query |
False |
Filter by rules.allow_device_creation
rules.index |
integer |
query |
False |
Filter by rules.index |
rules.protocols |
string |
query |
False |
Filter by rules.protocols |
rules.anonymous_user |
string |
query |
False |
Filter by rules.anonymous_user |
rules.allow_suid |
boolean |
query |
False |
Filter by rules.allow_suid
rules.allow_nfs_tls_only |
boolean |
query |
False |
Filter by rules.allow_nfs_tls_only
rules.ro_rule |
string |
query |
False |
Filter by rules.ro_rule |
rules.clients.match |
string |
query |
False |
Filter by rules.clients.match |
rules.rw_rule |
string |
query |
False |
Filter by rules.rw_rule |
name |
string |
query |
False |
Filter by name
id |
integer |
query |
False |
Filter by id |
are_rules_truncated |
boolean |
query |
False |
Filter by are_rules_truncated
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of export policy records |
records |
array[export_policy] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"id": 0,
"name": "string",
"rules": [
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"ntfs_unix_security": "string",
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262197 |
The value provided is invalid for the field |
2621462 |
The specified SVM name does not exist |
2621519 |
SVM name is invalid. The SVM name must begin with a letter or an underscore. If the SVM is of type "sync-source", the maximum supported length is 41. Otherwise, the maximum supported length is 47 |
2621643 |
The specified SVM name is too long |
2621685 |
SVM name length cannot be zero |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name |
6691623 |
User is not authorized |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
export_rules
_links |
boolean |
Specifies whether or not device creation is allowed. |
boolean |
Specifies whether to allow NFS access only over TLS connections. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
string |
NTFS export UNIX security options. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm
_links |
name |
string |
uuid |
string |
export_policy
_links |
boolean |
Indicates whether or not export-policy rules are truncated. |
id |
integer |
Export Policy ID |
name |
string |
Export Policy Name |
rules |
array[export_rules] |
Rules of the Export Policy. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
