List key servers configured in an external key manager
Retrieves a list of key servers configured in an external key manager, giving you insight into your key management setup. You might use this information to verify server configurations or troubleshoot key server connectivity issues.
HTTP method and endpoint
GET /security/key-managers/{uuid}/key-servers
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
connectivity.cluster_availability -
connectivity.node_states.node.name -
connectivity.node_states.node.uuid -
connectivity.node_states.state
Related ONTAP commands
security key-manager external show -
security key-manager external show-status
uuid |
string |
path |
True |
External key manager UUID |
server |
string |
query |
False |
Filter by server |
connectivity.cluster_availability |
boolean |
query |
False |
Filter by connectivity.cluster_availability
connectivity.node_states.node.name |
string |
query |
False |
Filter by connectivity.node_states.node.name
connectivity.node_states.node.uuid |
string |
query |
False |
Filter by connectivity.node_states.node.uuid
connectivity.node_states.state |
string |
query |
False |
Filter by connectivity.node_states.state
timeout |
integer |
query |
False |
Filter by timeout
secondary_key_servers |
string |
query |
False |
Filter by secondary_key_servers
username |
string |
query |
False |
Filter by username |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[key_server] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"connectivity": {
"node_states": [
"node": {
"name": "node1",
"state": "not_responding"
"password": "password",
"secondary_key_servers": [
"secondary1.com",
"10.1.2.3"
"server": "keyserver1.com:5698",
"timeout": 60,
"username": "username"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
key_server_state
The connectivity state of the key server for a specific node.
node |
state |
string |
Key server connectivity state |
connectivity
This property contains the key server connectivity state of all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
boolean |
Set to true when key server connectivity state is available on all nodes of the cluster. |
node_states |
array[key_server_state] |
An array of key server connectivity states for each node. |
records
_links |
connectivity |
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
KMIP username credentials for connecting with the key server. |
key_server
_links |
connectivity |
password |
string |
array[string] |
A list of the secondary key servers associated with the primary key server. |
server |
string |
timeout |
integer |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
