REST API reference
List key servers configured in an external key manager
Retrieves a list of key servers configured in an external key manager, helping you understand the current key management setup.
HTTP method and endpoint
GET /security/key-managers/{uuid}/key-servers
Introduced in
ONTAP 9.6
uuid
string
path
True
External key manager UUID
timeout
integer
query
False
Filter by timeout
username
string
query
False
Filter by username
secondary_key_servers
string
query
False
Filter by secondary_key_servers
  • Introduced in: 9.8
server
string
query
False
Filter by server
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[key_server]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "password": "password",
      "secondary_key_servers": [
        "string"
      "server": "keyserver1.com:5698",
      "timeout": "60",
      "username": "username"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
records
_links
_links
password
string
Password credentials for connecting with the key server. This is not audited.
array[string]
A list of the secondary key servers associated with the primary key server.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if records is provided.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
KMIP username credentials for connecting with the key server.
key_server
_links
_links
password
string
array[string]
server
string
timeout
integer
username
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
