REST API reference
List key servers configured in an external key manager
Retrieves a list of key servers configured in an external key manager. Use this endpoint when you need to review or manage the key servers involved in your external key management setup.
HTTP method and endpoint
GET /security/key-managers/{uuid}/key-servers
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See Requesting specific fields to learn more.
  • connectivity.cluster_availability
  • connectivity.node_states.node.name
  • connectivity.node_states.node.uuid
  • connectivity.node_states.state
  • security key-manager external show
  • security key-manager external show-status
uuid
string
path
True
External key manager UUID
username
string
query
False
Filter by username
string
query
False
Filter by connectivity.node_states.state
  • Introduced in: 9.13
string
query
False
Filter by connectivity.node_states.node.uuid
string
query
False
Filter by connectivity.node_states.node.name
boolean
query
False
Filter by connectivity.cluster_availability
  • Introduced in: 9.7
server
string
query
False
Filter by server
timeout
integer
query
False
Filter by timeout
  • Max value: 60
  • Min value: 1
secondary_key_servers
string
query
False
Filter by secondary_key_servers
  • Introduced in: 9.8
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[key_server]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "connectivity": {
        "node_states": [
            "node": {
              "name": "node1",
            "state": "not_responding"
      "password": "password",
      "secondary_key_servers": [
        "secondary1.com",
        "10.1.2.3"
      "server": "keyserver1.com:5698",
      "timeout": 60,
      "username": "username"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
node
_links
_links
name
string
uuid
string
key_server_state
The connectivity state of the key server for a specific node.
node
node
state
string
Key server connectivity state
connectivity
This property contains the key server connectivity state of all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
boolean
Set to true when key server connectivity state is available on all nodes of the cluster.
node_states
array[key_server_state]
An array of key server connectivity states for each node.
records
_links
_links
connectivity
connectivity
password
string
Password credentials for connecting with the key server. This is not audited.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if records is provided.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
KMIP username credentials for connecting with the key server.
key_server
_links
_links
connectivity
connectivity
password
string
array[string]
A list of the secondary key servers associated with the primary key server.
server
string
timeout
integer
username
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
