List key servers configured in an external key manager
Retrieves the list of key servers configured in an external key manager. Use this endpoint to access details about the key servers for security management purposes.
HTTP method and endpoint
GET /security/key-managers/{uuid}/key-servers
Introduced in
ONTAP 9.6
Expensive properties
There is an added computational cost to retrieving these properties. They are excluded from default GET results and must be explicitly requested using the fields query parameter. For more details, see Requesting specific fields. Additionally, these fields are unavailable for inactive configurations as they are only relevant to active configurations.
connectivity.cluster_availability -
connectivity.node_states.node.name -
connectivity.node_states.node.uuid -
connectivity.node_states.state
To retrieve basic information about a key server:
GET /security/key-managers/{uuid}/key-servers -
To retrieve specific fields, including expensive properties:
GET /security/key-managers/{uuid}/key-servers?fields=connectivity.cluster_availability,connectivity.node_states.node.name
Related ONTAP commands
security key-manager external show -
security key-manager external show-status
uuid |
string |
path |
True |
External key manager UUID |
create_remove_timeout |
integer |
query |
False |
Filter by create_remove_timeout
server |
string |
query |
False |
Filter by server |
connectivity.cluster_availability |
boolean |
query |
False |
Filter by connectivity.cluster_availability
connectivity.node_states.state |
string |
query |
False |
Filter by connectivity.node_states.state
connectivity.node_states.node.name |
string |
query |
False |
Filter by connectivity.node_states.node.name
connectivity.node_states.node.uuid |
string |
query |
False |
Filter by connectivity.node_states.node.uuid
timeout |
integer |
query |
False |
Filter by timeout
secondary_key_servers |
string |
query |
False |
Filter by secondary_key_servers
username |
string |
query |
False |
Filter by username |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[key_server] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"connectivity": {
"node_states": [
"node": {
"name": "node1",
"state": "not_responding"
"create_remove_timeout": 60,
"password": "password",
"port": 5698,
"secondary_key_servers": [
"secondary1.com",
"10.1.2.3"
"server": "keyserver1.com:5698",
"timeout": 60,
"username": "username"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
key_server_state
The connectivity state of the key server for a specific node.
node |
state |
string |
Key server connectivity state |
connectivity
This property contains the key server connectivity state of all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
boolean |
Set to true when key server connectivity state is available on all nodes of the cluster. |
node_states |
array[key_server_state] |
An array of key server connectivity states for each node. |
records
_links |
connectivity |
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
port |
integer |
TCP port number for the key server. |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
KMIP username credentials for connecting with the key server. |
key_server
_links |
connectivity |
integer |
The key server timeout for create and remove operations. -1 indicates that the server will wait indefinitely for the event to occur. 0 indicates that the server will not wait and will immediately timeout if it does not receive a response. |
password |
string |
port |
integer |
array[string] |
A list of the secondary key servers associated with the primary key server. |
server |
string |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. -1 indicates that the server will wait indefinitely for the event to occur. 0 indicates that the server will not wait and will immediately timeout if it does not receive a response. |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
