REST API reference
List key servers configured in an external key manager
Retrieves the list of key servers configured in an external key manager to understand the current server configurations and manage security settings effectively.
HTTP method and endpoint
GET /security/key-managers/{uuid}/key-servers
Introduced in
ONTAP 9.6
  • security key-manager external show
  • security key-manager external show-status
uuid
string
path
True
External key manager UUID
username
string
query
False
Filter by username
timeout
integer
query
False
Filter by timeout
secondary_key_servers
string
query
False
Filter by secondary_key_servers
  • Introduced in: 9.8
server
string
query
False
Filter by server
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[key_server]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "password": "password",
      "secondary_key_servers": [
        "string"
      "server": "keyserver1.com:5698",
      "timeout": 60,
      "username": "username"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
records
_links
_links
password
string
Password credentials for connecting with the key server. This is not audited.
array[string]
A list of the secondary key servers associated with the primary key server.
server
string
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if records is provided.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
KMIP username credentials for connecting with the key server.
key_server
_links
_links
password
string
array[string]
server
string
timeout
integer
username
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
