List key servers configured in an external key manager
GET /security/key-managers/{uuid}/key-servers
Retrieves the list of key servers configured in an external key manager.
uuid |
string |
path |
True |
External key manager UUID |
server |
string |
query |
False |
Filter by server |
connectivity.cluster_availability |
boolean |
query |
False |
Filter by connectivity.cluster_availability |
connectivity.records.state |
string |
query |
False |
Filter by connectivity.records.state |
connectivity.records.node.uuid |
string |
query |
False |
Filter by connectivity.records.node.uuid |
connectivity.records.node.name |
string |
query |
False |
Filter by connectivity.records.node.name |
username |
string |
query |
False |
Filter by username |
timeout |
integer |
query |
False |
Filter by timeout |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[key_server] |
"next": {
"href": "/api/resourcelink"
"records": [
"connectivity": {
"records": [
"node": {
"name": "node1",
"state": "not_responding"
"password": "password",
"server": "keyserver1.com:5698",
"timeout": 60,
"username": "username"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
node
_links |
name |
string |
uuid |
string |
key_server_state
The state of the key server for a specific node.
node |
state |
string |
Key server connectivity state |
connectivity
This property returns the key server connectivity state on all nodes of the cluster. The state is returned for a node only if the connectivity is not in an available state on that node.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
boolean |
Set to true when key server connectivity state is available on all nodes of the cluster. |
records |
array[key_server_state] |
An array of key server connectivity states for each node. |
records
_links |
connectivity |
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
KMIP username credentials for connecting with the key server. |
key_server
_links |
connectivity |
password |
string |
server |
string |
timeout |
integer |
username |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
