REST API reference
Update an Ethernet switch
Updates an Ethernet switch configuration, ensuring that the switch settings are current and optimized for network operations.
HTTP method and endpoint
PATCH /network/ethernet/switches/{name}
Introduced in
ONTAP 9.8
Usage notes
Update Ethernet Switch REST API
name
string
path
True
Switch Name
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
monitoring
monitoring
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
Example request
  "address": "string",
  "monitoring": {
    "reason": "string"
  "serial_number": "string",
  "snmp": {
    "user": "string",
    "version": "string"
  "version": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
12517378
Settings updated, but the IP address "{address}" is not reachable. Verify that the address is valid or check the network path.
12517380
Settings updated, but the SNMP validation request timed out. Verify that the "snmp.user" parameter is valid.
12517382
Settings updated, but the SNMP validation request timed out. Verify that the "snmp.user" parameter is valid (i.e., the SNMPv3 user exists in ONTAP and on the remote switch). If the "snmp.user" parameter is valid, verify that the SNMPv3 user's credentials are the same both in ONTAP as well as in the remote switch. If a custom engine-id was provided for the SNMPv3 user, ensure it is the same as that of the remote switch.
string
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
switch
address
string
IP Address.
discovered
boolean
  • readOnly: 1
  • x-nullable: true
monitoring
monitoring
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
