Update an Ethernet switch
Updates the state of an Ethernet switch to reflect changes in your network configuration or operational requirements.
HTTP method and endpoint
PATCH /network/ethernet/switches/{name}
Introduced in
ONTAP 9.8
Usage notes
Updates the switch state.
Related ONTAP commands
system switch ethernet modify
Learn more
name |
string |
path |
True |
Switch Name |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
address |
string |
IP Address. |
discovered |
boolean |
Discovered By ONTAP CDP/LLDP
monitoring |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
Example request
"address": "string",
"monitoring": {
"reason": "string"
"serial_number": "string",
"snmp": {
"user": "string",
"version": "string"
"version": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12517378 |
Settings updated, but the IP address "{address}" is not reachable. Verify that the address is valid or check the network path. |
12517380 |
Settings updated, but the SNMP validation request timed out. Verify that the "snmp.user" parameter is valid. |
12517382 |
Settings updated, but the SNMP validation request timed out. Verify that the "snmp.user" parameter is valid (i.e., the SNMPv3 user exists in ONTAP and on the remote switch). If the "snmp.user" parameter is valid, verify that the SNMPv3 user's credentials are the same both in ONTAP as well as in the remote switch. If a custom engine-id was provided for the SNMPv3 user, ensure it is the same as that of the remote switch. |
href |
string |
self_link
monitoring
enabled |
boolean |
Enable Health Monitoring. |
monitored |
boolean |
Is Monitored. |
reason |
string |
Reason For Not Monitoring. |
snmp
user |
string |
Community String or SNMPv3 Username. |
version |
string |
SNMP Version. |
switch
Ethernet Switch REST API
address |
string |
IP Address. |
discovered |
boolean |
monitoring |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
