REST API reference
Update an Ethernet switch
Updates an Ethernet switch configuration, modifying its settings to meet your network requirements.
HTTP method and endpoint
PATCH /network/ethernet/switches/{name}
Introduced in
ONTAP 9.8
Usage notes
Update Ethernet Switch REST API
name
string
path
True
Switch Name
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
Example request
  "address": "string",
  "model": "string",
  "monitoring": {
    "reason": "string"
  "name": "string",
  "network": "string",
  "serial_number": "string",
  "snmp": {
    "user": "string",
    "version": "string"
  "version": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
switch
address
string
IP Address.
discovered
boolean
  • readOnly: 1
model
string
Model Number.
monitoring
monitoring
name
string
Name.
network
string
Switch Network.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
