REST API reference
Update an Ethernet switch
Configures monitoring settings for an Ethernet switch to manage and monitor switch performance effectively.
HTTP method and endpoint
PATCH /network/ethernet/switches/{name}
Introduced in
ONTAP 9.8
  • system switch ethernet modify
name
string
path
True
Switch Name
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
address
string
IP Address.
discovered
boolean
Discovered By ONTAP CDP/LLDP
  • readOnly: 1
  • Introduced in: 9.8
  • x-nullable: true
monitoring
monitoring
rcf_version
string
The switch reference configuration file (RCF) version.
role
string
Switch role based on the interface configurations. Using '+' to combine multiple roles. Available role types are: cluster, multicluster, storage, multistorage, metrocluster.
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
Example request
  "address": "string",
  "monitoring": {
    "reason": "string"
  "rcf_version": "RCF NX9336C-FX2 v1.13 1-CLUSTER",
  "role": [
    "cluster+storage"
  "serial_number": "string",
  "snmp": {
    "user": "string",
    "version": "string"
  "version": "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
5636148
Failed to discover SNMPv3 engine ID of the remote switch.
5636149
The "\" must be a valid SNMPv3 user belonging to remote switch \"\" and must also be configured in ONTAP.
5636152
0.0.0.0 cannot be specified as the IP address for the "\" parameter.
8912900
Invalid IP address.
9044009
SNMPv3 client feature is not available until the effective cluster version is ONTAP 9.3 or later.
12517379
Warning: Settings updated, but the IP "\" is not reachable. Verify that the address is valid, or check the network path.
12517381
Warning: Settings updated, but the SNMP validation request timed out. Verify that the "\" parameter is valid.
12517383
Warning: Settings updated, but the SNMPv3 validation request timed out. Verify that the "\" parameter is valid (i.e., the SNMPv3 user exists in ONTAP and on the remote switch). If the \"\" parameter is valid, verify that the SNMPv3 user's credentials are the same both in ONTAP as well as in the remote switch. If a custom engine-id was provided for the SNMPv3 user, ensure it is the same as that of the remote switch.
12517411
The input value for "\", \"\" and/or \"\" must match its discovered value.
string
monitoring
enabled
boolean
Enable Health Monitoring.
monitored
boolean
Is Monitored.
reason
string
Reason For Not Monitoring.
snmp
user
string
Community String or SNMPv3 Username.
version
string
SNMP Version.
switch
Ethernet Switch REST API
address
string
IP Address.
discovered
boolean
  • readOnly: 1
  • x-nullable: true
monitoring
monitoring
rcf_version
string
role
string
serial_number
string
Serial Number.
snmp
snmp
version
string
Software Version.
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
