Update an Ethernet switch
Configures monitoring settings for an Ethernet switch to manage and monitor switch performance effectively.
HTTP method and endpoint
PATCH /network/ethernet/switches/{name}
Introduced in
ONTAP 9.8
Related ONTAP commands
system switch ethernet modify
Learn more
name |
string |
path |
True |
Switch Name |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
address |
string |
IP Address. |
discovered |
boolean |
Discovered By ONTAP CDP/LLDP
monitoring |
rcf_version |
string |
The switch reference configuration file (RCF) version. |
role |
string |
Switch role based on the interface configurations. Using '+' to combine multiple roles. Available role types are: cluster, multicluster, storage, multistorage, metrocluster. |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
Example request
"address": "string",
"monitoring": {
"reason": "string"
"rcf_version": "RCF NX9336C-FX2 v1.13 1-CLUSTER",
"role": [
"cluster+storage"
"serial_number": "string",
"snmp": {
"user": "string",
"version": "string"
"version": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636148 |
Failed to discover SNMPv3 engine ID of the remote switch. |
5636149 |
The " |
5636152 |
0.0.0.0 cannot be specified as the IP address for the " |
8912900 |
Invalid IP address. |
9044009 |
SNMPv3 client feature is not available until the effective cluster version is ONTAP 9.3 or later. |
12517379 |
Warning: Settings updated, but the IP " |
12517381 |
Warning: Settings updated, but the SNMP validation request timed out. Verify that the " |
12517383 |
Warning: Settings updated, but the SNMPv3 validation request timed out. Verify that the " |
12517411 |
The input value for " |
href |
string |
self_link
monitoring
enabled |
boolean |
Enable Health Monitoring. |
monitored |
boolean |
Is Monitored. |
reason |
string |
Reason For Not Monitoring. |
snmp
user |
string |
Community String or SNMPv3 Username. |
version |
string |
SNMP Version. |
switch
Ethernet Switch REST API
address |
string |
IP Address. |
discovered |
boolean |
monitoring |
rcf_version |
string |
role |
string |
serial_number |
string |
Serial Number. |
snmp |
version |
string |
Software Version. |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
