Update a service policy for network interfaces
Updates the service policy for network interfaces to modify the rules that govern network traffic behavior. This helps you manage how data flows through the network, ensuring it meets specific performance and security requirements.
HTTP method and endpoint
PATCH /network/ip/service-policies/{uuid}
Introduced in
ONTAP 9.8
uuid |
string |
path |
True |
UUID of the service policy |
Request Body
| Name | Type | Description |
is_built_in |
boolean |
name |
string |
services |
array[string] |
uuid |
string |
Example request
"name": "default-intercluster",
"services": [
"data_nfs"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376669 |
Port must reside in the same IPspace as the interface's SVM. |
53281929 |
Service policies cannot combine block and file services. |
53281930 |
Service policies maintained by the system cannot be renamed. |
53281931 |
Service policy names cannot start with "default-". |
53281932 |
Service cannot be added because the service does not exist for the specified SVM or IPspace. |
53281933 |
A Cluster-scoped service cannot be added to a SVM-scoped service policy. |
53281934 |
An SVM-scoped service cannot be added to a Cluster-scoped service policy. |
53281952 |
The service policy on an SVM cannot be updated to include a block service. Use built-in service policies for SAN services. |
53281953 |
The service policy on an SVM cannot be updated to include a new service. |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
The name of the SVM. |
uuid |
string |
ip_service_policy
is_built_in |
boolean |
name |
string |
services |
array[string] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
