REST API reference
Update a service policy for network interfaces
Updates the service policy for network interfaces to modify the rules and settings applied to network traffic. Use this when you need to change how services are prioritized or managed on your network interfaces.
HTTP method and endpoint
PATCH /network/ip/service-policies/{uuid}
Introduced in
ONTAP 9.8
uuid
string
path
True
UUID of the service policy
Request Body
Name Type Description
is_built_in
boolean
name
string
services
array[string]
uuid
string
Example request
  "name": "default-intercluster",
  "services": [
    "data_nfs"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1376669
Port must reside in the same IPspace as the interface's SVM.
53281893
The service cannot be removed because it is used by one or more interfaces.
53281911
Modifying the service policy is disallowed because policies on this SVM are managed by the system
53281929
Service policies cannot combine block and file services.
53281930
Service policies maintained by the system cannot be renamed.
53281931
Service policy names cannot start with "default-".
53281932
Service cannot be added because the service does not exist for the specified SVM or IPspace.
53281933
A Cluster-scoped service cannot be added to a SVM-scoped service policy.
53281934
An SVM-scoped service cannot be added to a Cluster-scoped service policy.
53281952
The service policy on an SVM cannot be updated to include a block service. Use built-in service policies for SAN services.
53281953
The service policy on an SVM cannot be updated to include a new service.
string
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
svm
name
string
The name of the SVM.
uuid
string
ip_service_policy
is_built_in
boolean
name
string
services
array[string]
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
