Update a service policy for network interfaces
Updates a service policy for network interfaces to modify the existing network configurations as required.
HTTP method and endpoint
PATCH /network/ip/service-policies/{uuid}
Introduced in
ONTAP 9.8
Related ONTAP commands
network interface service-policy add-service -
network interface service-policy modify-service -
network interface service-policy remove-service -
network interface service-policy rename
uuid |
string |
path |
True |
UUID of the service policy |
Request Body
| Name | Type | Description |
is_built_in |
boolean |
name |
string |
services |
array[string] |
uuid |
string |
Example request
"name": "default-intercluster",
"services": [
"data_nfs"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376669 |
Port must reside in the same IPspace as the interface's SVM. |
2621740 |
An unexpected error when trying to determine whether the target Vserver was locked or not on this cluster. |
53281911 |
Modifying the service policy is disallowed because policies on this SVM are managed by the system |
53281929 |
Service policies cannot combine block and file services. |
53281930 |
Service policies maintained by the system cannot be renamed. |
53281931 |
Service policy names cannot start with "default-". |
53281932 |
Service cannot be added because the service does not exist for the specified SVM or IPspace. |
53281933 |
A Cluster-scoped service cannot be added to a SVM-scoped service policy. |
53281934 |
An SVM-scoped service cannot be added to a Cluster-scoped service policy. |
53281952 |
The service policy on an SVM cannot be updated to include a block service. Use built-in service policies for SAN services. |
53281953 |
The service policy on an SVM cannot be updated to include a new service. |
53281961 |
Service cannot be removed from the service policy because it is used by one or more interfaces. |
53281963 |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
uuid |
string |
ip_service_policy
is_built_in |
boolean |
name |
string |
services |
array[string] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
