Update a service policy for network interfaces
PATCH /network/ip/service-policies/{uuid}
Introduced In: 9.8
Updates a service policy for network interfaces.
Related ONTAP commands
network interface service-policy add-service -
network interface service-policy modify-service -
network interface service-policy remove-service -
network interface service-policy rename
uuid  |
string  |
path  |
True  |
UUID of the service policy  |
Request Body
| Name | Type | Description |
is_built_in  |
boolean  |
name  |
string  |
services  |
array[string]  |
uuid  |
string  |
Example request
  "name": "default-intercluster",
  "services": [
    "data_nfs"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376669  |
Port must reside in the same IPspace as the interface's SVM.  |
2621740  |
An unexpected error when trying to determine whether the target Vserver was locked or not on this cluster.  |
53281911  |
Modifying the service policy is disallowed because policies on this SVM are managed by the system  |
53281929  |
Service policies cannot combine block and file services.  |
53281930  |
Service policies maintained by the system cannot be renamed.  |
53281931  |
Service policy names cannot start with "default-".  |
53281932  |
Service cannot be added because the service does not exist for the specified SVM or IPspace.  |
53281933  |
A Cluster-scoped service cannot be added to a SVM-scoped service policy.  |
53281934  |
An SVM-scoped service cannot be added to a Cluster-scoped service policy.  |
53281952  |
The service policy on an SVM cannot be updated to include a block service. Use built-in service policies for SAN services.  |
53281953  |
The service policy on an SVM cannot be updated to include a new service.  |
53281960  |
Service cannot be removed from the service policy because it is used by one or more interfaces.  |
53281961  |
53281963  |
href  |
string  |
_links
ipspace
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
ip_service_policy
is_built_in  |
boolean  |
name  |
string  |
services  |
array[string]  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
