Update a service policy for network interfaces
Updates a service policy for network interfaces to modify the rules that govern how services interact with network resources. This can be useful when adjusting policies to accommodate changing network requirements or optimizing service performance.
HTTP method and endpoint
PATCH /network/ip/service-policies/{uuid}
Introduced in
ONTAP 9.8
Related ONTAP commands
network interface service-policy add-service -
network interface service-policy modify-service -
network interface service-policy remove-service -
network interface service-policy rename
uuid |
string |
path |
True |
UUID of the service policy |
Request Body
| Name | Type | Description |
is_built_in |
boolean |
name |
string |
services |
array[string] |
uuid |
string |
Example request
"name": "default-intercluster",
"services": [
"data_nfs"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1376669 |
Port must reside in the same IPspace as the interface's SVM. |
2621740 |
An unexpected error when trying to determine whether the target Vserver was locked or not on this cluster. |
53281911 |
Modifying the service policy is disallowed because policies on this SVM are managed by the system |
53281929 |
Service policies cannot combine block and file services. |
53281930 |
Service policies maintained by the system cannot be renamed. |
53281931 |
Service policy names cannot start with "default-". |
53281932 |
Service cannot be added because the service does not exist for the specified SVM or IPspace. |
53281933 |
A Cluster-scoped service cannot be added to a SVM-scoped service policy. |
53281934 |
An SVM-scoped service cannot be added to a Cluster-scoped service policy. |
53281952 |
The service policy on an SVM cannot be updated to include a block service. Use built-in service policies for SAN services. |
53281953 |
The service policy on an SVM cannot be updated to include a new service. |
53281961 |
Service cannot be removed from the service policy because it is used by one or more interfaces. |
53281963 |
href |
string |
_links
ipspace
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
uuid |
string |
ip_service_policy
is_built_in |
boolean |
name |
string |
services |
array[string] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
