REST API reference
Report cluster-wide storage details across different tiers
Reports storage details across different tiers within the cluster, giving you a comprehensive overview of storage usage and configuration. This information can help you manage resources effectively across various storage tiers.
HTTP method and endpoint
GET /storage/cluster
Introduced in
ONTAP 9.6
Usage notes
Reports cluster wide storage details across different tiers. By default, this endpoint returns all fields. Supports the following roles: admin, and readonly.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
block_storage
block_storage
cloud_storage
cloud_storage
efficiency
space_efficiency
Storage efficiency
efficiency_without_snapshots
space_efficiency
Storage efficiency that does not include the savings provided by Snapshot copies.
efficiency_without_snapshots_flexclones
space_efficiency
Storage efficiency that does not include the savings provided by Snapshot copies and FlexClones.
  "block_storage": {
    "medias": [
        "efficiency": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "efficiency_without_snapshots": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "efficiency_without_snapshots_flexclones": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "type": "string"
  "cloud_storage": {
    "used": 0
  "efficiency": {
    "logical_used": 0,
    "ratio": 0,
    "savings": 0
    "logical_used": 0,
    "ratio": 0,
    "savings": 0
    "logical_used": 0,
    "ratio": 0,
    "savings": 0
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
space_efficiency
Storage Efficiency
logical_used
integer
Logical used
ratio
number
Data reduction ratio (logical_used / used)
savings
integer
Space saved by storage efficiencies (logical_used - used)
space_efficiency
logical_used
integer
Logical used
ratio
number
savings
integer
space_efficiency
logical_used
integer
Logical used
ratio
number
savings
integer
medias
available
integer
Available space
efficiency
space_efficiency
Storage Efficiency
space_efficiency
space_efficiency
physical_used
integer
Total physical used space
size
integer
Total space
type
string
The type of media being used
used
integer
Used space
block_storage
available
integer
Available space across the cluster
inactive_data
integer
Inactive data across all aggregates
medias
array[medias]
physical_used
integer
Total physical used space across the cluster
size
integer
Total space across the cluster
used
integer
Space used (includes volume reserves)
cloud_storage
used
integer
Total space used in cloud.
space_efficiency
Storage efficiency
logical_used
integer
Logical used
ratio
number
savings
integer
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
