Report cluster-wide storage details across different tiers
Reports detailed storage information across various tiers within a cluster. This is useful when you need comprehensive insights into your storage configuration and utilization.
HTTP method and endpoint
GET /storage/cluster
Introduced in
ONTAP 9.6
Usage notes
Reports cluster wide storage details across different tiers. By default, this endpoint returns all fields. Supports the following roles: admin, and readonly.
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
desc] direction. Default direction is 'asc' for ascending. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
block_storage |
cloud_storage |
efficiency |
Storage efficiency |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by Snapshot copies. |
efficiency_without_snapshots_flexclones |
Storage efficiency that does not include the savings provided by Snapshot copies and FlexClones. |
"block_storage": {
"medias": [
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots_flexclones": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"type": "string"
"cloud_storage": {
"used": 0
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
space_efficiency
Storage Efficiency
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
space_efficiency
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
space_efficiency
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
medias
available |
integer |
Available space |
efficiency |
Storage Efficiency |
size |
integer |
Total space |
type |
string |
The type of media being used |
used |
integer |
Used space |
block_storage
inactive_data |
integer |
Inactive data across all aggregates |
medias |
array[medias] |
physical_used |
integer |
Total physical used space across the cluster |
size |
integer |
Total space across the cluster |
used |
integer |
Space used (includes volume reserves) |
cloud_storage
used |
integer |
Total space used in cloud. |
space_efficiency
Storage efficiency
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
