Report cluster-wide storage details across different tiers
Accesses cluster-wide storage details across different tiers, including storage efficiency and information on block and cloud storage. Use this to gather comprehensive storage insights for management and monitoring purposes.
HTTP method and endpoint
GET /storage/cluster
Introduced in
ONTAP 9.6
Usage notes
Retrieves cluster-wide storage details across the different tiers. By default, this endpoint returns all fields. Storage details include storage efficiency, block storage and cloud storage information. Supports the following roles: admin, and readonly.
cloud_storage.used |
integer |
query |
False |
Filter by cloud_storage.used
efficiency.savings |
integer |
query |
False |
Filter by efficiency.savings
efficiency.logical_used |
integer |
query |
False |
Filter by efficiency.logical_used
efficiency.ratio |
number |
query |
False |
Filter by efficiency.ratio
efficiency_without_snapshots.savings |
integer |
query |
False |
Filter by efficiency_without_snapshots.savings
efficiency_without_snapshots.logical_used |
integer |
query |
False |
Filter by efficiency_without_snapshots.logical_used
efficiency_without_snapshots.ratio |
number |
query |
False |
Filter by efficiency_without_snapshots.ratio
efficiency_without_snapshots_flexclones.savings |
integer |
query |
False |
Filter by efficiency_without_snapshots_flexclones.savings
efficiency_without_snapshots_flexclones.logical_used |
integer |
query |
False |
Filter by efficiency_without_snapshots_flexclones.logical_used
efficiency_without_snapshots_flexclones.ratio |
number |
query |
False |
Filter by efficiency_without_snapshots_flexclones.ratio
block_storage.medias.used |
integer |
query |
False |
Filter by block_storage.medias.used
block_storage.medias.available |
integer |
query |
False |
Filter by block_storage.medias.available
block_storage.medias.efficiency.savings |
integer |
query |
False |
Filter by block_storage.medias.efficiency.savings
block_storage.medias.efficiency.logical_used |
integer |
query |
False |
Filter by block_storage.medias.efficiency.logical_used
block_storage.medias.efficiency.ratio |
number |
query |
False |
Filter by block_storage.medias.efficiency.ratio
block_storage.medias.efficiency_without_snapshots.savings |
integer |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots.savings
block_storage.medias.efficiency_without_snapshots.logical_used |
integer |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots.logical_used
block_storage.medias.efficiency_without_snapshots.ratio |
number |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots.ratio
block_storage.medias.size |
integer |
query |
False |
Filter by block_storage.medias.size
block_storage.medias.efficiency_without_snapshots_flexclones.savings |
integer |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.savings
block_storage.medias.efficiency_without_snapshots_flexclones.logical_used |
integer |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.logical_used
block_storage.medias.efficiency_without_snapshots_flexclones.ratio |
number |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.ratio
block_storage.medias.type |
string |
query |
False |
Filter by block_storage.medias.type
block_storage.medias.physical_used |
integer |
query |
False |
Filter by block_storage.medias.physical_used
block_storage.inactive_data |
integer |
query |
False |
Filter by block_storage.inactive_data
block_storage.physical_used |
integer |
query |
False |
Filter by block_storage.physical_used
block_storage.size |
integer |
query |
False |
Filter by block_storage.size
block_storage.used |
integer |
query |
False |
Filter by block_storage.used
block_storage.available |
integer |
query |
False |
Filter by block_storage.available
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
block_storage |
Configuration information for the locally attached portion of all the aggregates across the cluster. When a cloud store is also used by an aggregate, this is referred to as the performance tier. |
cloud_storage |
Configuration information for the cloud storage portion of all the aggregates across the cluster. This is referred to as the capacity tier. |
efficiency |
Storage efficiency. |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by Snapshot copies. |
efficiency_without_snapshots_flexclones |
Storage efficiency that does not include the savings provided by Snapshot copies and FlexClones. |
"block_storage": {
"medias": [
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots_flexclones": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"type": "string"
"cloud_storage": {
"used": 0
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
efficiency
Storage efficiency.
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
medias
available |
integer |
Available space of all the aggregates based on media type. |
efficiency |
physical_used |
integer |
Total physical used space of all the aggregates based on media type. |
size |
integer |
Total space of all the aggregates based on media type. |
type |
string |
The type of media being used. |
used |
integer |
Used space of all the aggregates based on media type. |
block_storage
available |
integer |
Available space of all aggregates across the cluster. |
inactive_data |
integer |
Inactive data of all aggregates across the cluster. |
medias |
array[medias] |
Configuration information based on type of media. For example, SSD media type information includes the sum of all the SSD aggregates across the cluster. |
physical_used |
integer |
Total physical used space of all aggregates across the cluster. |
size |
integer |
Total space of all aggregates across the cluster. |
used |
integer |
Used space (includes volume reserves) of the all aggregates across the cluster. |
cloud_storage
used |
integer |
Total space used in cloud. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
