Report cluster-wide storage details across different tiers
Retrieves comprehensive storage details across different tiers in your cluster, including efficiency metrics and information on block and cloud storage. Use this endpoint to gather insights into your cluster's storage configuration.
HTTP method and endpoint
GET /storage/cluster
Introduced in
ONTAP 9.6
Usage notes
Retrieves cluster-wide storage details across the different tiers. By default, this endpoint returns all fields. Storage details include storage efficiency, block storage and cloud storage information. Supports the following roles: admin, and readonly.
block_storage.physical_used |
integer |
query |
False |
Filter by block_storage.physical_used
block_storage.inactive_data |
integer |
query |
False |
Filter by block_storage.inactive_data
block_storage.used |
integer |
query |
False |
Filter by block_storage.used
block_storage.available |
integer |
query |
False |
Filter by block_storage.available
block_storage.size |
integer |
query |
False |
Filter by block_storage.size
block_storage.medias.efficiency.savings |
integer |
query |
False |
Filter by block_storage.medias.efficiency.savings
block_storage.medias.efficiency.logical_used |
integer |
query |
False |
Filter by block_storage.medias.efficiency.logical_used
block_storage.medias.efficiency.ratio |
number |
query |
False |
Filter by block_storage.medias.efficiency.ratio
block_storage.medias.efficiency_without_snapshots_flexclones.savings |
integer |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.savings
block_storage.medias.efficiency_without_snapshots_flexclones.logical_used |
integer |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.logical_used
block_storage.medias.efficiency_without_snapshots_flexclones.ratio |
number |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.ratio
block_storage.medias.type |
string |
query |
False |
Filter by block_storage.medias.type
block_storage.medias.size |
integer |
query |
False |
Filter by block_storage.medias.size
block_storage.medias.efficiency_without_snapshots.savings |
integer |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots.savings
block_storage.medias.efficiency_without_snapshots.logical_used |
integer |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots.logical_used
block_storage.medias.efficiency_without_snapshots.ratio |
number |
query |
False |
Filter by block_storage.medias.efficiency_without_snapshots.ratio
block_storage.medias.physical_used |
integer |
query |
False |
Filter by block_storage.medias.physical_used
block_storage.medias.used |
integer |
query |
False |
Filter by block_storage.medias.used
block_storage.medias.available |
integer |
query |
False |
Filter by block_storage.medias.available
integer |
query |
False |
Filter by efficiency_without_snapshots.savings
integer |
query |
False |
Filter by efficiency_without_snapshots.logical_used
number |
query |
False |
Filter by efficiency_without_snapshots.ratio
integer |
query |
False |
Filter by efficiency_without_snapshots_flexclones.savings
integer |
query |
False |
Filter by efficiency_without_snapshots_flexclones.logical_used
number |
query |
False |
Filter by efficiency_without_snapshots_flexclones.ratio
integer |
query |
False |
Filter by efficiency.savings
integer |
query |
False |
Filter by efficiency.logical_used
efficiency.ratio |
number |
query |
False |
Filter by efficiency.ratio
cloud_storage.used |
integer |
query |
False |
Filter by cloud_storage.used
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
block_storage |
Configuration information for the locally attached portion of the storage across the cluster. When a cloud store is also used by the storage, this is referred to as the performance tier. |
cloud_storage |
Configuration information for the cloud storage portion of all the aggregates across the cluster. This is referred to as the capacity tier. |
efficiency |
Storage efficiency. |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by snapshots. |
efficiency_without_snapshots_flexclones |
Storage efficiency that does not include the savings provided by snapshots and FlexClone volumes. |
metric |
Cluster capacity numbers, such as total size, used size, and available size. |
"block_storage": {
"available": 0,
"inactive_data": 0,
"medias": [
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots_flexclones": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"type": "string"
"physical_used": 0,
"size": 0,
"used": 0
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
"metric": {
"href": "/api/resourcelink"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
efficiency
Storage efficiency.
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
medias
available |
integer |
Available space across the cluster based on media type. |
efficiency |
physical_used |
integer |
Total physical used space across the cluster based on media type. |
size |
integer |
Total space across the cluster based on media type. |
type |
string |
The type of media being used. |
used |
integer |
Used space across the cluster based on media type. |
block_storage
available |
integer |
Available space across the cluster. |
inactive_data |
integer |
Inactive data across the cluster. |
medias |
array[medias] |
Configuration information based on type of media. For example, SSD media type information includes the sum of all the SSD storage across the cluster. |
physical_used |
integer |
Total physical used space across the cluster. |
size |
integer |
Total space across the cluster. |
used |
integer |
Used space (includes volume reserves) across the cluster. |
cloud_storage
used |
integer |
Total space used in cloud. |
href |
string |
_links
self |
metric
_links |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
