REST API reference
Report cluster-wide storage details across different tiers
Retrieves comprehensive cluster-wide storage details across various tiers, including information on storage efficiency, block storage, and cloud storage. This endpoint helps you understand the overall storage configuration and utilization within your cluster.
HTTP method and endpoint
GET /storage/cluster
Introduced in
ONTAP 9.6
Usage notes
Retrieves cluster-wide storage details across the different tiers. By default, this endpoint returns all fields. Storage details include storage efficiency, block storage and cloud storage information. Supports the following roles: admin, and readonly.
  • cluster space show
efficiency.savings
integer
query
False
Filter by efficiency.savings
  • Introduced in: 9.14
efficiency.logical_used
integer
query
False
Filter by efficiency.logical_used
efficiency.ratio
number
query
False
Filter by efficiency.ratio
efficiency_without_snapshots.savings
integer
query
False
Filter by efficiency_without_snapshots.savings
efficiency_without_snapshots.logical_used
integer
query
False
Filter by efficiency_without_snapshots.logical_used
efficiency_without_snapshots.ratio
number
query
False
Filter by efficiency_without_snapshots.ratio
efficiency_without_snapshots_flexclones.savings
integer
query
False
Filter by efficiency_without_snapshots_flexclones.savings
efficiency_without_snapshots_flexclones.logical_used
integer
query
False
Filter by efficiency_without_snapshots_flexclones.logical_used
efficiency_without_snapshots_flexclones.ratio
number
query
False
Filter by efficiency_without_snapshots_flexclones.ratio
cloud_storage.used
integer
query
False
Filter by cloud_storage.used
block_storage.medias.size
integer
query
False
Filter by block_storage.medias.size
block_storage.medias.used
integer
query
False
Filter by block_storage.medias.used
block_storage.medias.available
integer
query
False
Filter by block_storage.medias.available
block_storage.medias.type
string
query
False
Filter by block_storage.medias.type
block_storage.medias.efficiency_without_snapshots_flexclones.savings
integer
query
False
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.savings
block_storage.medias.efficiency_without_snapshots_flexclones.logical_used
integer
query
False
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.logical_used
block_storage.medias.efficiency_without_snapshots_flexclones.ratio
number
query
False
Filter by block_storage.medias.efficiency_without_snapshots_flexclones.ratio
block_storage.medias.efficiency.savings
integer
query
False
Filter by block_storage.medias.efficiency.savings
block_storage.medias.efficiency.logical_used
integer
query
False
Filter by block_storage.medias.efficiency.logical_used
block_storage.medias.efficiency.ratio
number
query
False
Filter by block_storage.medias.efficiency.ratio
block_storage.medias.efficiency_without_snapshots.savings
integer
query
False
Filter by block_storage.medias.efficiency_without_snapshots.savings
block_storage.medias.efficiency_without_snapshots.logical_used
integer
query
False
Filter by block_storage.medias.efficiency_without_snapshots.logical_used
block_storage.medias.efficiency_without_snapshots.ratio
number
query
False
Filter by block_storage.medias.efficiency_without_snapshots.ratio
block_storage.medias.physical_used
integer
query
False
Filter by block_storage.medias.physical_used
block_storage.physical_used
integer
query
False
Filter by block_storage.physical_used
block_storage.inactive_data
integer
query
False
Filter by block_storage.inactive_data
block_storage.available
integer
query
False
Filter by block_storage.available
block_storage.size
integer
query
False
Filter by block_storage.size
block_storage.used
integer
query
False
Filter by block_storage.used
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
block_storage
block_storage
Configuration information for the locally attached portion of the storage across the cluster. When a cloud store is also used by the storage, this is referred to as the performance tier.
cloud_storage
cloud_storage
Configuration information for the cloud storage portion of all the aggregates across the cluster. This is referred to as the capacity tier.
efficiency
efficiency
Storage efficiency.
Storage efficiency that does not include the savings provided by snapshots.
Storage efficiency that does not include the savings provided by snapshots and FlexClone volumes.
metric
metric
Cluster capacity numbers, such as total size, used size, and available size.
  "block_storage": {
    "available": 0,
    "inactive_data": 0,
    "medias": [
        "efficiency": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "efficiency_without_snapshots": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "efficiency_without_snapshots_flexclones": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "type": "string"
    "physical_used": 0,
    "size": 0,
    "used": 0
  "efficiency": {
    "logical_used": 0,
    "ratio": 0,
    "savings": 0
    "logical_used": 0,
    "ratio": 0,
    "savings": 0
    "logical_used": 0,
    "ratio": 0,
    "savings": 0
  "metric": {
        "href": "/api/resourcelink"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
efficiency
Storage efficiency.
logical_used
integer
Logical used
ratio
number
Data reduction ratio (logical_used / used)
savings
integer
Space saved by storage efficiencies (logical_used - used)
logical_used
integer
Logical used
ratio
number
savings
integer
logical_used
integer
Logical used
ratio
number
savings
integer
medias
available
integer
Available space across the cluster based on media type.
efficiency
efficiency
Storage efficiency.
physical_used
integer
Total physical used space across the cluster based on media type.
size
integer
Total space across the cluster based on media type.
type
string
The type of media being used.
used
integer
Used space across the cluster based on media type.
block_storage
available
integer
Available space across the cluster.
inactive_data
integer
Inactive data across the cluster.
medias
array[medias]
Configuration information based on type of media. For example, SSD media type information includes the sum of all the SSD storage across the cluster.
physical_used
integer
Total physical used space across the cluster.
size
integer
Total space across the cluster.
used
integer
Used space (includes volume reserves) across the cluster.
cloud_storage
used
integer
Total space used in cloud.
string
self
metric
_links
_links
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
