REST API reference
Creates an export policy rule
  • clientsmatch - list of clients (hostnames, ipaddresses, netgroups, domains) to which the export rule applies
  • ro_rule - used to specify the security type for read-only access to volumes that use the export rule
  • rw_rule - used to specify the security type for read-write access to volumes that use the export rule # default property values if not specified in post, the following default property values are assigned:
  • protocols - any
  • anonymous_user - none
  • superuser - any # related ontap commands
  • vserver export-policy rule create # learn more
  • [doc /protocols/nfs/export-policies](#docs-nas-protocols_nfs_export-policies)
POST /protocols/nfs/export-policies/{policy.id}/rules
Creates an export policy rule.
Required properties
  • policy.id - Existing export policy for which to create an export rule.
  • clients.match - List of clients (hostnames, ipaddresses, netgroups, domains) to which the export rule applies.
  • ro_rule - Used to specify the security type for read-only access to volumes that use the export rule.
  • rw_rule - Used to specify the security type for read-write access to volumes that use the export rule.
Default property values
If not specified in POST, the following default property values are assigned:
  • protocols - any
  • superuser - any
policy.id
integer
path
True
Export Policy ID
Request Body
Name Type Description
_links
_links
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
clients
array[export_client]
Array of client matches
index
integer
Index of the rule within the export policy.
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
Example request
      "href": "/api/resourcelink"
  "anonymous_user": "string",
  "clients": [
      "match": "0.0.0.0/0"
  "index": 0,
  "protocols": [
    "string"
  "ro_rule": [
    "string"
  "rw_rule": [
    "string"
  "superuser": [
    "string"
Status: 201, Created
_links
_links
num_records
integer
Number of Export Rule records
records
array[export_rule]
    "next": {
  "records": [
      "clients": [
      "index": 0,
      "protocols": [
        "string"
      "ro_rule": [
        "string"
      "rw_rule": [
        "string"
      "superuser": [
        "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
1703954
Export policy does not exist
1704036
Invalid clientmatch: missing domain name
1704037
Invalid clientmatch: missing network name
1704038
Invalid clientmatch: missing netgroup name
1704039
Invalid clientmatch
1704040
Invalid clientmatch: address bytes masked out by netmask are non-zero
1704041
Invalid clientmatch: address bytes masked to zero by netmask
1704042
Invalid clientmatch: too many bits in netmask
1704043
Invalid clientmatch: invalid netmask
1704044
Invalid clientmatch: invalid characters in host name
1704045
Invalid clientmatch: invalid characters in domain name
1704050
Invalid clientmatch: clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported
1704051
Warning: Not adding any new strings to the clientmatch field for ruleindex. All of the match strings are already in the clientmatch list
1704064
Clientmatch host name too long
1704065
Clientmatch domain name too long
3277000
Upgrade all nodes to Data ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules
3277083
User ID is not valid. Enter a value for User ID from 0 to 4294967295
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
export_client
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
export_rule
_links
_links
anonymous_user
string
clients
index
integer
protocols
array[string]
ro_rule
array[string]
rw_rule
array[string]
superuser
array[string]
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
