Retrieve AKVs configured for all clusters and SVMs
GET /security/azure-key-vaults
Introduced In: 9.8
Retrieves AKVs configured for all clusters and SVMs.
Related ONTAP commands
security key-manager external azure show
svm.uuid  |
string  |
query  |
False  |
Filter by svm.uuid  |
svm.name  |
string  |
query  |
False  |
Filter by svm.name  |
tenant_id  |
string  |
query  |
False  |
Filter by tenant_id  |
state.code  |
integer  |
query  |
False  |
Filter by state.code  |
state.message  |
string  |
query  |
False  |
Filter by state.message  |
state.cluster_state  |
boolean  |
query  |
False  |
Filter by state.cluster_state  |
scope  |
string  |
query  |
False  |
Filter by scope  |
name  |
string  |
query  |
False  |
Filter by name  |
key_id  |
string  |
query  |
False  |
Filter by key_id  |
uuid  |
string  |
query  |
False  |
Filter by uuid  |
client_id  |
string  |
query  |
False  |
Filter by client_id  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
max_records  |
integer  |
query  |
False  |
Limit the number of records returned.  |
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
order_by  |
array[string]  |
query  |
False  |
Order results by specified fields and optional [asc  |
Status: 200, Ok
| Name | Type | Description |
_links  |
num_records  |
integer  |
Number of records  |
records  |
array[azure_key_vault]  |
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "client_id": "aaaaaaaa-bbbb-aaaa-bbbb-aaaaaaaaaaaa",
      "key_id": "https://keyvault1.vault.azure.net/keys/key1/a8e619fd8f234db3b0b95c59540e2a74",
      "name": "https://kmip-akv-keyvault.vault.azure.net/",
      "scope": "string",
      "state": {
        "code": "346758",
        "message": "AKV key protection is unavailable in following nodes - node1, node2."
      "svm": {
        "name": "svm1",
      "tenant_id": "zzzzzzzz-yyyy-zzzz-yyyy-zzzzzzzzzzzz",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
next  |
self  |
_links
self  |
state
Indicates whether the AKV key protection is available cluster wide.
cluster_state  |
boolean  |
Set to true when AKV key protection is available on all nodes of the cluster.  |
code  |
integer  |
Code corresponding to the status message. Returns a 0 if AKV key protection is available in all nodes of the cluster.  |
message  |
string  |
Error message set when cluster availability is false.  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
azure_key_vault
_links  |
client_id  |
string  |
Application client ID of the deployed Azure application with appropriate access to an AKV.  |
key_id  |
string  |
Key Identifier of AKV key encryption key.  |
name  |
string  |
Name of the deployed AKV that will be used by ONTAP for storing keys.
scope  |
string  |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".  |
state  |
Indicates whether the AKV key protection is available cluster wide.  |
svm  |
tenant_id  |
string  |
Directory (tenant) ID of the deployed Azure application with appropriate access to an AKV.  |
uuid  |
string  |
A unique identifier for the Azure Key Vault (AKV).  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
