Create or remove litigations for a path
POST /storage/snaplock/litigations/{litigation.id}/operations
Introduced In: 9.7
Creates or removes litigations for the specified path.
Required properties
type- Legal-Hold operation type. -
path- Litigation path.
Related ONTAP commands
snaplock legal-hold begin -
snaplock legal-hold end
litigation.id  |
string  |
path  |
True  |
Litigation ID  |
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
id  |
integer  |
Operation ID.  |
num_files_failed  |
string  |
Specifies the number of files on which legal-hold operation failed.  |
num_files_processed  |
string  |
Specifies the number of files on which legal-hold operation was successful.  |
num_files_skipped  |
string  |
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.  |
num_inodes_ignored  |
string  |
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.  |
path  |
string  |
Specifies the path on which legal-hold operation is applied.  |
state  |
string  |
Specifies the status of legal-hold operation.  |
Example request
  "id": "16842759",
  "num_files_failed": "0",
  "num_files_processed": "30",
  "num_files_skipped": "10",
  "num_inodes_ignored": "10",
  "path": "/dir1",
  "state": "completed"
Status: 201, Created
id  |
integer  |
Operation ID.  |
num_files_failed  |
string  |
string  |
num_files_skipped  |
string  |
string  |
path  |
string  |
state  |
string  |
  "id": "16842759",
  "path": "/dir1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090346  |
Internal Error. Wait a few minutes, then try the command again  |
14090343  |
Invalid Field  |
href  |
string  |
_links
snaplock_legal_hold_operation
id  |
integer  |
Operation ID.  |
num_files_failed  |
string  |
string  |
num_files_skipped  |
string  |
string  |
path  |
string  |
state  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
