ONTAP Select
Supported network configurations
Select the best hardware and configure your network to optimize performance and resiliency.
Server vendors understand that customers have different needs and choice is critical. As a result, when purchasing a physical server, there are numerous options available when making network connectivity decisions. Most commodity systems ship with various NIC choices that provide single-port and multiport options with varying permutations of speed and throughput. This includes support for 25Gb/s and 40Gb/s NIC adapters with VMware ESX.
Because the performance of the ONTAP Select VM is tied directly to the characteristics of the underlying hardware, increasing the throughput to the VM by selecting higher-speed NICs results in a higher-performing cluster and a better overall user experience. Four 10Gb NICs or two higher-speed NICs (25/40 Gb/s) can be used to achieve a high performance network layout. There are a number of other configurations that are also supported. For two-node clusters, 4 x 1Gb ports or 1 x 10Gb ports are supported. For single node clusters, 2 x 1Gb ports are supported.
Network minimum and recommended configurations
There are several supported Ethernet configurations based on the cluster size.
Cluster size Minimum Requirements Recommendation
Single node cluster
2 x 1GbE
2 x 10GbE
Two-node cluster or MetroCluster SDS
4 x 1GbE or 1 x 10GbE
2 x 10GbE
4/6/8 node cluster
2 x 10GbE
4 x 10GbE or 2 x 25/40GbE
Note Conversion between single link and multiple link topologies on a running cluster is not supported because of the possible need to convert between different NIC teaming configurations required for each topology.
Network configuration using multiple physical switches
When sufficient hardware is available, NetApp recommends using the multiswitch configuration shown in the following figure, due to the added protection against physical switch failures.
