Upgrade to the latest release of ONTAP tools
When you upgrade from ONTAP tools for VMware vSphere 10.0 and 10.1 to 10.1, a recovery volume is created and all the necessary details are taken into the recovery volume. The recovery volume can be used to recover the ONTAP tools for VMware vSphere setup if you need to recover your configuration. If you’re performing a patch-level upgrade of ONTAP tools for VMware vSphere 10.1, the same recovery volume is used and the details are refreshed. Upgrade is supported for both HA and non-HA deployments.
Before you begin
You need to complete the following steps before proceeding with the upgrade task:
Enable Diagnostics
From vCenter Server, open a console to ONTAP tools.
Log in as the maintenance user.
Enter 4 to select Support and Diagnostics.
Enter 2 to select Enable remote diagnostic access.
Enter y to set the password of your choice.
Login to VM IP address from the terminal/putty with user as 'diag' and password that was set in the previous step.
Take Backup of MongoDB
Run the following commands to take a backup of mongoDB:
kn exec -it ntv-mongodb-0 sh - kn is an alias of kubectl -n ntv-system.
env | grep MONGODB_ROOT_PASSWORD - run this command inside the pod.
'exit' - run this to come out of the pod.
kn exec ntv-mongodb-0 --mongodump -u root -p MONGODB_ROOT_PASSWORD --archive=/tmp/mongodb-backup.gz --gzip - run this command to replace MONGO_ROOT_PASSWORD set from above command.
kn cp ntv-mongodb-0:/tmp/mongodb-backup.gz ./mongodb-backup.gz - run this command to copy the mongodb backup created using above command from pod to host.
Take the snapshot of all the volumes
Run 'kn get pvc' command and save the output of the command.
Take snapshots of all the volumes one by one using one of the following methods:
From CLI, run the command volume snapshot create -vserver <vserver_name> -volume <volume_name> -snapshot <snapshot_name>
From ONTAP system manager user interface search the volume by its name in the search bar then open that volume by clicking on the name. Go to snapshot and add the snapshot of that volume.
Take the snapshot of ONTAP tools for VMware vSphere VMs in vCenter (3VMs in case of HA Deployment, 1 VM in case of non-HA deployment)
In the vSphere client user interface, select the VM.
Go to the snapshots tab and click the Take Snapshot button.
From the log bundle, delete the completed pods with prefix “generate-support-bundle-job” before performing the upgrade. If support bundle generation is in progress, wait for it to complete and then delete the pod.
Steps
Upload ONTAP tools for VMware vSphere upgrade ISO to content library.
In the primary VM page, select Actions > Edit Settings
In the edit settings window under CD/DVD drive field select content library ISO file.
Select the ISO file and click OK. Choose the connected checkbox across the CD/DVD drive field.
Enter 3 to select the System Configuration menu.
Enter 7 to select the upgrade option.
When you upgrade, the following actions are performed automatically:
Certificate upgrade
Remote plug-in upgrade
