Monitor disaster recovery jobs
You can monitor all disaster recovery jobs and determine their progress.
From the BlueXP left nav, select Protection > Disaster recovery.
From the top menu, select Job monitoring.
Explore all jobs related to operations and review their timestamps and status.
To view details of a particular job, select that row.
To refresh information, select Refresh.
Cancel a job
If a job is in progress and you don't want it to continue, you can cancel it. You might want to cancel a job if it is stuck in the same state and you want to free up the next operation in the queue. You might want cancel a job before it times out.
To cancel a job, you use Swagger.
To cancel a job, you must have the Account ID.
In the Job monitor page, note the ID of the job you want to cancel.
Access the BlueXP disaster recovery Swagger URL: Swagger.
"https://snapcenter.cloudmanager.cloud.netapp.com/api-doc/#/Jobs/put_jobmanager_v2_jobs__jobId_"
For details about Swagger, see Swagger docs.
From Swagger, obtain the security token, also called the bearer token, from the Authorize option.
Enter the Account ID and Job ID.
Select Try it out.
