Navigating to pre-defined OnCommand Insight reports
PDF of this doc site
- Configuration and administration
- Data Warehouse administration
Creating your file...
Your file is ready
When you open the Reporting Portal, the Team content folder is the starting point for you to select the type of information that you require in the OnCommand Insight reports.
Steps
In the left navigation pane, click Team content and select the information category that you want to use.
Click Reports to access the pre-defined reports.
Click Get Started, Samples or Tutorials to learn how to create reports.
