Upgrade Astra Control Center
To upgrade Astra Control Center, download the installation bundle from the NetApp Support Site and complete these instructions to upgrade the Astra Control Center components in your environment. You can use this procedure to upgrade Astra Control Center in internet-connected or air-gapped environments.
Ensure all cluster operators are in a healthy state and available.
OpenShift example:
oc get clusteroperators
Ensure all API services are in a healthy state and available.
OpenShift example:
oc get apiservices
Log out of your Astra Control Center.
The Astra Control Center upgrade process guides you through the following high-level steps:
Do not execute the following command during the entirety of the upgrade process to avoid deleting all Astra Control Center pods: kubectl delete -f astra_control_center_operator_deploy.yaml
Perform upgrades in a maintenance window when schedules, backups, and snapshots are not running. |
Podman commands can be used in place of Docker commands if you are using Red Hat’s Podman instead of Docker Engine. |
Download the Astra Control Center bundle
Download the Astra Control Center upgrade bundle (
astra-control-center-[version].tar.gz
) from the NetApp Support Site. -
(Optional) Use the following command to verify the signature of the bundle:
openssl dgst -sha256 -verify astra-control-center[version].pub -signature <astra-control-center[version].sig astra-control-center[version].tar.gz
Unpack the bundle and change directory
Extract the images:
tar -vxzf astra-control-center-[version].tar.gz
Change to the Astra directory.
cd astra-control-center-[version]
Add the images to your local registry
Add the files in the Astra Control Center image directory to your local registry.
See a sample script for the automatic loading of images below. -
Log in to your Docker registry:
docker login [your_registry_path]
Load the images into Docker.
Tag the images.
Push the images to your local registry.
export REGISTRY=[your_registry_path] for astraImageFile in $(ls images/*.tar) # Load to local cache. And store the name of the loaded image trimming the 'Loaded images: ' do astraImage=$(docker load --input ${astraImageFile} | sed 's/Loaded image: //') astraImage=$(echo ${astraImage} | sed 's!localhost/!!') # Tag with local image repo. docker tag ${astraImage} ${REGISTRY}/${astraImage} # Push to the local repo. docker push ${REGISTRY}/${astraImage} done
Install the updated Astra Control Center operator
Edit the Astra Control Center operator deployment yaml (
) to refer to your local registry and secret.vim astra_control_center_operator_deploy.yaml
If you use a registry that requires authentication, replace the default line of
imagePullSecrets: []
with the following:imagePullSecrets: - name: <name_of_secret_with_creds_to_local_registry>
Change
for thekube-rbac-proxy
image to the registry path where you pushed the images in a previous step. -
Change
for theacc-operator-controller-manager
Add the following values to the
env
section:- name: ACCOP_HELM_UPGRADETIMEOUT value: 300m
apiVersion: apps/v1 kind: Deployment metadata: labels: control-plane: controller-manager name: acc-operator-controller-manager namespace: netapp-acc-operator spec: replicas: 1 selector: matchLabels: control-plane: controller-manager template: metadata: labels: control-plane: controller-manager spec: containers: - args: - --secure-listen-address=0.0.0.0:8443 - --upstream=http://127.0.0.1:8080/ - --logtostderr=true - --v=10 image: [your_registry_path]/kube-rbac-proxy:v4.8.0 name: kube-rbac-proxy ports: - containerPort: 8443 name: https - args: - --health-probe-bind-address=:8081 - --metrics-bind-address=127.0.0.1:8080 - --leader-elect command: - /manager env: - name: ACCOP_LOG_LEVEL value: "2" - name: ACCOP_HELM_UPGRADETIMEOUT value: 300m image: [your_registry_path]/acc-operator:[version x.y.z] imagePullPolicy: IfNotPresent imagePullSecrets: []
Install the updated Astra Control Center operator:
kubectl apply -f astra_control_center_operator_deploy.yaml
Sample response:
namespace/netapp-acc-operator unchanged customresourcedefinition.apiextensions.k8s.io/astracontrolcenters.astra.netapp.io configured role.rbac.authorization.k8s.io/acc-operator-leader-election-role unchanged clusterrole.rbac.authorization.k8s.io/acc-operator-manager-role configured clusterrole.rbac.authorization.k8s.io/acc-operator-metrics-reader unchanged clusterrole.rbac.authorization.k8s.io/acc-operator-proxy-role unchanged rolebinding.rbac.authorization.k8s.io/acc-operator-leader-election-rolebinding unchanged clusterrolebinding.rbac.authorization.k8s.io/acc-operator-manager-rolebinding configured clusterrolebinding.rbac.authorization.k8s.io/acc-operator-proxy-rolebinding unchanged configmap/acc-operator-manager-config unchanged service/acc-operator-controller-manager-metrics-service unchanged deployment.apps/acc-operator-controller-manager configured
Edit the Astra Control Center custom resource (CR) (
astra_control_center_min.yaml
) and change the Astra version (astraVersion
inside ofSpec
) number to the latest:kubectl edit acc -n [netapp-acc or custom namespace]
Your registry path must match the registry path where you pushed the images in a previous step. -
Add the following lines within
additionalValues
inside ofSpec
in the Astra Control Center CR:additionalValues: nautilus: startupProbe: periodSeconds: 30 failureThreshold: 600
Do one of the following:
If you don't have your own IngressController or ingress and have been using the Astra Control Center with its Traefik gateway as a LoadBalancer type service and would like to continue with that setup, specify another field
ingressType
(if not already present) and set it toAccTraefik
.ingressType: AccTraefik
If you want to switch to the default Astra Control Center generic ingress deployment, provide your own IngressController/Ingress setup (with TLS termination, etc.), open up a route to Astra Control Center, and set
ingressType
toGeneric
.ingressType: Generic
If you omit the field, the process becomes the generic deployment. If you don't want the generic deployment, be sure to add the field.
(Optional) Verify that the pods terminate and become available again:
watch kubectl get po -n [netapp-acc or custom namespace]
Wait for the Astra status conditions to indicate that the upgrade is complete and ready:
kubectl get -o yaml -n [netapp-acc or custom namespace] astracontrolcenters.astra.netapp.io astra
Response:
conditions: - lastTransitionTime: "2021-10-25T18:49:26Z" message: Astra is deployed reason: Complete status: "True" type: Ready - lastTransitionTime: "2021-10-25T18:49:26Z" message: Upgrading succeeded. reason: Complete status: "False" type: Upgrading
Log back in and verify that all managed clusters and apps are still present and protected.
If the operator did not update the Cert-manager, upgrade third-party services, next.
Upgrade third-party services (Optional)
The third-party services Traefik and Cert-manager are not upgraded during earlier upgrade steps. You can optionally upgrade them using the procedure described here or retain existing service versions if your system requires it.
Traefik: By default, Astra Control Center manages the lifecycle of the Traefik deployment. Setting
externalTraefik
tofalse
(default) indicates that no external Traefik exists in the system and and Traefik is being installed and managed by Astra Control Center. In this case,externalTraefik
is set tofalse
.On the other hand, if you have your own Traefik deployment, set
externalTraefik
totrue
. In this case, you maintain the deployment and Astra Control Center will not upgrade the CRDs, unlessshouldUpgrade
is set totrue
Cert-manager: By default, Astra Control Center installs the cert-manager (and CRDs) unless you set
externalCertManager
totrue
. SetshouldUpgrade
totrue
to have Astra Control Center upgrade the CRDs.
Traefik is upgraded if any of the following conditions are met:
externalTraefik: false
OR -
externalTraefik: true AND shouldUpgrade: true.
Edit the
acc
CR:kubectl edit acc -n [netapp-acc or custom namespace]
Change the
externalTraefik
field and theshouldUpgrade
field to eithertrue
orfalse
as needed.crds: externalTraefik: false externalCertManager: false shouldUpgrade: false
Verify system status
Log in to Astra Control Center.
Verify that all your managed clusters and apps are still present and protected.
Set up ingress for load balancing
You can set up a Kubernetes ingress object that manages external access to the services, such as load balancing in a cluster.
Default upgrade uses the generic ingress deployment. In this case, you will also need to set up an ingress controller or ingress resource.
If you don't want an ingress controller and want to retain what you already have, set
ingressType
toAccTraefik
For additional details about the service type of "LoadBalancer" and ingress, see Requirements. |
The steps differ depending on the type of ingress controller you use:
Nginx ingress controller
OpenShift ingress controller
In the CR spec,
If
crd.externalTraefik
is present, it should be set tofalse
OR -
If
crd.externalTraefik
istrue
,crd.shouldUpgrade
should also betrue
The required ingress controller should already be deployed.
The ingress class corresponding to the ingress controller should already be created.
You are using Kubernetes versions between and including v1.19 and v1.21.
Use the existing secret
secure-testing-cert
or create a secret of typekubernetes.io/tls
for a TLS private key and certificate innetapp-acc
(or custom-named) namespace as described in TLS secrets. -
Deploy an ingress resource in
netapp-acc
(or custom-named) namespace for either a deprecated or a new schema:-
For a deprecated schema, follow this sample:
apiVersion: extensions/v1beta1 kind: Ingress metadata: name: ingress-acc namespace: [netapp-acc or custom namespace] annotations: kubernetes.io/ingress.class: nginx spec: tls: - hosts: - <ACC address> secretName: [tls secret name] rules: - host: [ACC address] http: paths: - backend: serviceName: traefik servicePort: 80 pathType: ImplementationSpecific
For a new schema, follow this example:
apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: netapp-acc-ingress namespace: [netapp-acc or custom namespace] spec: ingressClassName: [class name for nginx controller] tls: - hosts: - <ACC address> secretName: [tls secret name] rules: - host: <ACC address> http: paths: - path: backend: service: name: traefik port: number: 80 pathType: ImplementationSpecific
Procure your certificate and get the key, certificate, and CA files ready for use by the OpenShift route.
Create the OpenShift route:
oc create route edge --service=traefik --port=web -n [netapp-acc or custom namespace] --insecure-policy=Redirect --hostname=<ACC address> --cert=cert.pem --key=key.pem
Verify ingress set up
You can verify the ingress set up before you continue.
Ensure that Traefik has changed to
clusterIP
from Loadbalancer:kubectl get service traefik -n [netapp-acc or custom namespace]
Verify routes in Traefik:
Kubectl get ingressroute ingressroutetls -n [netapp-acc or custom namespace] -o yaml | grep "Host("
The result should be empty.
