Use NetApp data services with Azure Blob storage
After you discover Azure Blob storage accounts in BlueXP, you can use NetApp data services for backup, tiering, and data synchronization.
Use BlueXP backup and recovery to back up data from your on-premises ONTAP and Cloud Volumes ONTAP systems to Azure Blob storage.
To get started, go to the Canvas and drag and drop an on-premises ONTAP or Cloud Volumes ONTAP working environment on your Azure Blob Storage working environment.
Use BlueXP tiering to tier inactive data from on-premises ONTAP clusters to Azure Blob storage.
To get started, go to the Canvas and drag and drop an on-premises ONTAP working environment on your Azure Blob Storage working environment.
Use BlueXP copy and sync to synchronize data to or from Azure Blob storage accounts.
To get started, go to the Canvas and drag and drop the source working environment on the target working environment. Your Azure Blob Storage working environment can be either the source or target.
You can also select your Azure Blob Storage working environment and click Copy & sync from the Services panel to synchronize data to or from Azure Blob storage accounts.
