BlueXP copy and sync
BlueXP copy and sync overview
Contributors netapp-bcammett netapp-ivanad
The NetApp BlueXP copy and sync service offers a simple, secure, and automated way to migrate your data to any target, in the cloud or on your premises. Whether it’s a file-based NAS dataset (NFS or SMB), Amazon Simple Storage Service (S3) object format, a NetApp StorageGRID® appliance, or any other cloud provider object store, BlueXP copy and sync can convert and move it for you.
Features
Watch the following video for an overview of BlueXP copy and sync:
How BlueXP copy and sync works
BlueXP copy and sync is a software-as-a-service (SaaS) platform that consists of a data broker group, a cloud-based interface available through BlueXP, and a source and target.
The following image shows the relationship between BlueXP copy and sync components:
Conceptual image that shows data flowing from a source to a target. The data broker software acts as a mediator and polls the BlueXP copy and sync service for tasks.
The NetApp data broker software syncs data from a source to a target (this is called a sync relationship). You can run the data broker in AWS, Azure, Google Cloud Platform, or on your premises. A data broker group, which consists of one or more data brokers, needs an outbound internet connection over port 443 so it can communicate with the BlueXP copy and sync service and contact a few other services and repositories. View the list of endpoints.
After the initial copy, the service syncs any changed data based on the schedule that you set.
Supported storage types
BlueXP copy and sync supports the following storage types:
  • Any NFS server
  • Any SMB server
  • Amazon EFS
  • Amazon FSx for ONTAP
  • Amazon S3
  • Azure Blob
  • Azure Data Lake Storage Gen2
  • Azure NetApp Files
  • Box (available as a preview)
  • Cloud Volumes ONTAP
  • Google Cloud Storage
  • Google Drive
  • IBM Cloud Object Storage
  • On-premises ONTAP cluster
  • ONTAP S3 Storage
  • SFTP (using API only)
  • StorageGRID
Costs
There are two types of costs associated with using BlueXP copy and sync: resource charges and service charges.
Resource charges
Resource charges are related to the compute and storage costs for running one or more data brokers in the cloud.
Service charges
There are two ways to pay for sync relationships after your 14-day free trial ends. The first option is to subscribe from AWS or Azure, which enables you to pay hourly or annually. The second option is to purchase licenses directly from NetApp.
