Creating and viewing reports to tune your configuration
Create and view reports to get information that you can use with the help of NetApp personnel to tune a data broker’s configuration and improve performance.
Each report provides in-depth details about a path in a sync relationship. For example, the report for a file system shows how many directories and files there are, the distribution of file size, how deep and wide the directories are, and more.
Creating reports
Each time that you create a report, BlueXP copy and sync scans the path and then compiles the details into a report.
Click Sync > Reports.
The paths (source or target) in each of your sync relationships display in a table.
In the Reports Actions column, go to a specific path and click Create, or click the action menu and select Create New.
When the report is ready, click the action menu and select View.
Here’s a sample report for a file system path.
And here’s a sample report for object storage.
Downloading reports
You can download a report in PDF so that you can view it offline or share it.
In the Reports Actions column, click the action menu and select View.
In the top right of the report, click the action menu and select Download pdf.
Viewing report errors
The Paths table identifies whether any errors are present in the most recent report. An error identifies an issue that BlueXP copy and sync faced when scanning the path.
For example, a report might contain permission denied errors. This type of error can affect BlueXP copy and sync’s ability to scan the entire set of files and directories.
After you view the list of errors, you can then address the issues and run the report again.
In the Errors column, identify whether any errors are present in a report.
If errors are present, click the arrow next to the number of errors.
Use the information in the error to correct the issue.
After you resolve the issue, the error shouldn’t appear the next time that you run the report.
Deleting reports
You might delete a report of it contained an error that you fixed, or if the report is related to a sync relationship that you removed.
In the Reports Actions column, click the action menu for a path and select Delete last report or Delete all reports.
Confirm that you want to delete the report or reports.
