Azure Blob storage
Add Azure Blob storage accounts
Contributors netapp-tonacki
Once your Azure Blob Storage working environment is available in the Canvas, you can add additional storage accounts directly from BlueXP.
Steps
  1. From the Canvas, double-click the Azure Blob Storage working environment to view the Azure Blob Storage Overview page, and click Add storage account.
    A screenshot that shows the details of an Azure Blob Storage working environment and the Add storage account button.
    The Add storage account page is displayed.
    A screenshot showing the Add storage account page so you can create your own Azure Blob storage accounts.
  2. Enter the required information in the Project details section.
    Field Description
    Subscription
    Select the Azure subscription for the new storage account.
    Resource group
    Select an existing resource group for this storage account.
  3. In the Instance details section, enter the name for the storage account, and select a region (or regions) where the storage account will be created.
    Field Description
    Storage account name
    Enter the name you want to use for the storage account. The name must be between 3 and 24 characters in length, and it can contain numbers and lowercase letters only.
    Azure Region
    Select a region from the list where the storage account will be created.
    Not all regions are supported for all types of storage accounts or redundancy configurations. See the Microsoft documentation for information about Azure Storage redundancy.
    Additionally, the choice of region can have a billing impact. See the Microsoft documentation for information about Azure Storage account billing.
    Performance type
    Select whether you want to use Standard or Premium performance storage. See the Microsoft documentation for information about Types of storage accounts.
    • Standard performance is used for general-purpose v2 storage accounts. This type of account is recommended for most scenarios.
    • Premium performance is used for scenarios that require low latency. There are three types of premium storage accounts are available: Block blobs, File shares, and Page blobs.
  4. In the Tags section, you can enter up to 10 tag key/value pairs to group your resources.
    Tags are metadata that you can use to group resources to identify applications, environments, regions, cloud providers, and more. You can add tags to a storage account so that the tags are applied to objects when they are added to the storage account.
    Tags are disabled by default in new storage accounts created by BlueXP. Learn more about tagging from the Microsoft documentation.
  5. In the Encryption section, choose the type of data encryption you want to use to protect access to the data in the storage account.
    Data encryption type Description
    Microsoft-managed keys
    By default, Microsoft-managed encryption keys are used to encrypt your data.
    Customer-managed keys
    You can use your own customer-managed keys for data encryption instead of using the default Microsoft-managed encryption keys. If you're planning to use your own customer-managed keys, you'll need to have created them already so you can select the Key Vault and the Keys in this page.
    The keys can be in the same Subscription as the storage account, or you can select a different Subscription.
  6. Click Add and the bucket is created.
