Lifecycle planning
Evaluate a system refresh with Lifecycle planning
Contributors netapp-barbe amgrissino
If you have existing assets in place and want to determine whether a system refresh is recommended, you can use the Lifecycle planning System refresh options. You can either review a short assessment of your current workloads and get recommendations, or if you have sent AutoSupport logs to NetApp within the past 90 days, the service can provide a workload simulation to see how your workloads perform on new hardware.
Systems are considered candidates for a system refresh based on the following:
  • Nearing the end of the Tech Support contract
  • Nearing the end of the hardware lifecycle
Tip You can access this feature either through Lifecycle planning or through Digital Advisor.
Take a refresh assessment
The assessment includes the following steps:
  • Select the systems you want to assess.
  • Specify your requirements regarding environments, workload types, capacity, performance, and budget.
  • View the recommendations regarding appropriate products and cloud services that might improve performance in your environment.
Steps
  1. Log in to the NetApp Console.
  2. Select System refresh.
    System refresh page showing the system refresh candidates
  3. Look at the System refresh candidates tab, which lists all the systems that might benefit from a system refresh.
  4. Select the system on which you want to obtain an assessment.
  5. From the Actions column, select Evaluate refresh.
    Systems to be included in the system refresh
  6. Select the system or systems on which you want the assessment performed and select Next.
  7. Define the requirements:
    1. Environments: Select the types of environment that you want: public cloud, hybrid cloud, or on-premises.
      System refresh Requirements page showing environment choices
    2. Workloads: Select all the types of workloads that you want to handle: Business critical applications, high performance analytics and computing, data lakes and media workflows, secondary storage, or less critical workloads.
      Workload choices
    3. Capacity: Enter the capacity requirements in TiB, slide the slider to the value, or place your cursor on the value in the slider and select Next.
    4. Performance: Select the performance aspects that you want to be able to handle: lowest latency, highest IOPS, mixed workloads, or performance not important and select Next.
      Performance choices
    5. Budget: Enter a budget in US dollars, slide the slider to the value, or place your cursor on the value in the slider and select Next.
      A set of recommendations appears in different tabs for the options you chose.
  8. Review the recommendations.
    View refresh assessment recommendations page
  9. Do one or both of the following:
    1. To download a PDF of the recommendations, select Download.
    2. To connect with a NetApp Sales Representative regarding the recommendations, select Contact Sales. A web page shows options you can choose from to contact a NetApp Sales Representative.
  10. Select Finish.
View system refresh assessments already taken
You can review the system refresh assessments that you already took and review the recommendations again.
Steps
  1. From the NetApp Console left navigation, select Storage > Lifecycle planning > System refresh.
  2. Select the System refresh candidates tab, which lists all the systems on which you took a system refresh assessment. Then, from the Actions menu on the row for that system, select to view the assessments and recommendations for that system.
  3. In the Evaluate refresh options page, select View recommendation.
  4. View the refresh recommendations.
Simulate workloads on new hardware
If you have sent AutoSupport logs in to NetApp within the past 90 days, NetApp is able to provide a simulation to see how your workloads perform on new hardware.
You can include or exclude specific workloads from the simulation. You can also add workloads if they don't appear in the existing workload list.
Steps
  1. From the NetApp Console left navigation, select Governance > Lifecycle planning > System refresh.
    System refresh page showing the System refresh candidates tab
  2. Look at the System refresh candidates tab, which lists all the systems that might benefit from a system refresh.
  3. Select the system on which you want to obtain an assessment.
  4. In the Actions column, select Evaluate refresh.
    Note lifecycle planning imports workload details in preparation for the simulation.
    Simulate workloads page showing the requirements options
  5. In the Simulate workloads > Workload requirements page, do the following:
    1. To add a workload not already in the list, select Add workload. For details, see Add a workload.
    2. IOPS: Optionally, change the IOPs that you want for your new hardware.
    3. Capacity (TiB): Optionally, change the capacity that you want for your new hardware.
  6. To exclude workloads, in the Actions column, select the Exclude workload from simulation option.
    Tip To include previously excluded workloads, select the Excluded workloads tab and select the Include workload in simulation option.
    .. Select Next.
  7. Review the simulated results on new hardware on the Configuration page:
    Simulate workloads page showing the simulation results
    Tip The best recommendations are denoted with a "Best" indication.
  8. To download a PDF of the recommendations, select Download.
  9. To connect with a NetApp Sales representative regarding the recommendations:
    1. Select Contact.
    2. Enter contact details.
    3. Add special notes for the NetApp Sales Representative.
    4. Select Confirm and submit.
  10. Select Finish.
Result
The recommendations from the workload simulation are sent to a NetApp Sales Representative. You will also receive an email confirming the recommendations. A NetApp Sales Representative will respond to your request.
Add a workload
You can add a workload that is not already listed to the workload simulation.
Steps
  3. Select the system.
  5. In the Simulate workloads > Workload requirements page, select Add workload.
    Add workload page
  6. Select the application, enter a workload name, and select a workload size.
  7. Enter the workload's expected capacity and performance values.
    Note If you chose the workload size of small, typical or one that is IO intensive, default values appear.
  8. Optionally, select the Advanced options arrow and change the defaults for the following information:
    • Storage efficiency: A typical data reduction ratio might be 2 to 1.
    • Random reads %: A typical average IO size for a random read is 16K.
    • Sequential reads %: A typical read pattern is 50% random and 50% sequential.
    • Random writes %: A typical average IO size for a random write is 32K.
    • Sequential writes %: A typical write pattern is 50% random and 50% sequential.
