StorageGRID
Remove a StorageGRID working environment
Contributors netapp-bcammett netapp-tonias
Remove a StorageGRID working environment if you no longer want to manage it from BlueXP.
Required BlueXP role:
Organization admin, Folder or project admin, or Storage admin. Learn about BlueXP access roles.
Removing the working environment doesn't affect the StorageGRID system. You can rediscover it from BlueXP at any time.
Steps
  1. From the navigation menu, select Storage > Canvas.
  2. From the Canvas page, open the StorageGRID working environment.
  3. From the standard view, select the menu icon and select Remove from Workspace.
    A screenshot of the Remove from Workspace option that is available in the top right menu of the working environment.
  4. Select Remove to confirm.
