What's New with Data Infrastructure Insights
NetApp is continually improving and enhancing its products and services. Here are some of the latest features and functionalities available in Data Infrastructure Insights (formerly Cloud Insights).
December 2020
Simpler Kubernetes Installation
Kubernetes Agent installation has been streamlined to require fewer user interactions. Installing the Kubernetes Agent now includes Kubernetes data collection.
November 2020
Additional Dashboards
The following new ONTAP-focused dashboards have been added to the gallery and are available for import:
ONTAP: Aggregate Performance & Capacity
ONTAP FAS/AFF - Capacity Utilization
ONTAP FAS/AFF - Cluster Capacity
ONTAP FAS/AFF - Efficiency
ONTAP FAS/AFF - FlexVol Performance
ONTAP FAS/AFF - Node Operational/Optimal Points
ONTAP FAS/AFF - PrePost Capacity Efficiencies
ONTAP: Network Port Activity
ONTAP: Node Protocols Performance
ONTAP: Node Workload Performance (Frontend)
ONTAP: Processor
ONTAP: SVM Workload Performance (Frontend)
ONTAP: Volume Workload Performance (Frontend)
Column Rename in Table Widgets
You can rename columns in the Metrics and Attributes section of a table widget by opening the widget in Edit mode and clicking the menu at the top of the column. Enter the new name and click Save, or click Reset to set the column back to the original name.
Note that this only affects the column's display name in the table widget; the metric/attribute name does not change in the underlying data itself.
October 2020
Default Expansion of Integration Data
Table widget grouping now allows for default expansions of Kubernetes, ONTAP Advanced Data, and Agent Node metrics. For example, if you group Kubernetes Nodes by Cluster, you will see a row in the table for each cluster. You could then expand each cluster row to see a list of the Node objects.
Basic Edition Technical Support
Technical Support is now available for subscribers to Cloud Insights Basic Edition in addition to Standard and Premium Editions. Additionally, Cloud Insights has simplified the workflow for creating a NetApp support ticket.
Cloud Secure Public API
Cloud Secure supports REST APIs for accessing Activity and Alert information. This is accomplished through the use of API Access Tokens, created through the Cloud Secure Admin UI, which are then used to access the REST APIs. Swagger documentation for these REST APIs is integrated with Cloud Secure.
September 2020
Query Page with Integration Data
The Cloud Insights Query page supports integration data (i.e. from Kubernetes, ONTAP Advanced Metrics, etc.). When working with integration data, the query results table displays a "Split-Screen" view, with object/grouping on the left side, and object data (attributes/metrics) on the right. You can also choose multiple attributes for grouping integration data.
Unit Display Formatting in Table Widget
Unit display formatting is now available in Table widgets for columns that display metric/counter data (for example, gigabytes, MB/second, etc.). To change a metric's display unit, click the "three dots" menu in the column header and select "Unit Display". You can choose from any of the available units. Available units will vary according to the type of metric data in the display column.
Acquisition Unit Detail Page
Acquisition Units now have their own landing page, providing useful detail for each AU as well as information to help with troubleshooting. The AU detail page provides links to the AU's data collectors as well as helpful status information.
Cloud Secure Docker Dependency Removed
Cloud Secure's dependency on Docker has been removed. Docker is no longer required for Cloud Secure agent installation.
Reporting User Roles
If you have Cloud Insights Premium Edition with Reporting, every Cloud Insights user in your environment also has a Single Sign-On (SSO) login to the Reporting application (i.e. Cognos); by clicking the Reports link in the menu, they will automatically be logged in to Reporting.
Their user role in Cloud Insights determines their Reporting user role:
Cloud Insights Role |
Reporting Role |
Reporting Permissions |
Guest |
Consumer |
Can view, schedule, and run reports and set personal preferences such as those for languages and time zones. Consumers cannot create reports or perform administrative tasks. |
User |
Author |
Can perform all Consumer functions as well as create and manage reports and dashboards. |
Administrator |
Administrator |
Can perform all Author functions as well as all administrative tasks such configuration of reports and the shutdown and restart of reporting tasks. |
Cloud Insights Reporting is available for environments of 500 MUs or more. |
If you are a current Premium Edition customer and wish to retain your reports, read this important note for existing customers. |
New API Category for Data Ingestion
Cloud Insights has added a Data Ingestion API category, giving you greater control over custom data and agents. Detailed documentation for this and other API Categories can be found in Cloud Insights by navigating to Admin > API Access and clicking the API Documentation link. You can also attach a comment to the AU in the Note field, which is displayed on the AU detail page as well as the AU list page.
August 2020
Monitoring and Alerting
In addition to the current ability to set performance policies for storage objects, VMs, EC2, and ports, Cloud Insights Standard Edition now includes the ability to configure monitors for thresholds on Integration data for Kubernetes, ONTAP advanced metrics, and Telegraf plugins. You simply create a monitor for each object metric you want to trigger alerts, set the conditions for warning-level or critical-level thresholds, and specify the email recipient(s) desired for each level. You can then view and manage alerts to track trends or troubleshoot issues.
July 2020
Cloud Secure Take a Snapshot Action
Cloud Secure protects your data by automatically taking a snapshot when malicious activity is detected, ensuring that your data is safely backed up.
You can define automated response policies that take a snapshot when ransomware attack or other abnormal user activity is detected.
You can also take a snapshot manually from the alert page.
Automatic Snapshot taken:
Manual Snapshot:
Metric/Counter updates
The following capacity counters are available for use in Cloud Insights UI and REST API. Previously these counters were only available for the Data Warehouse / Reporting.
| Object Type | Counter |
Storage |
Capacity - Spare Raw |
Storage Pool |
Data Capacity - Used |
Internal Volume |
Cloud Secure Potential Attack Detection
Cloud Secure now detects potential attacks such as ransomware. Click on an alert in the Alerts list page to open a detail page showing the following:
Time of attack
Associated user and file activity
Action taken
Additional information to assist with tracking down possible security breaches
Alerts page showing potential ransomware attack:
Detail page for potential ransomware attack:
Subscribe to Premium Edition through AWS
During your trial of Cloud Insights, you can self-subscribe through AWS Marketplace to either Cloud Insights Standard Edition or Premium Edition. Previously, you could only self-subscribe through AWS Marketplace to Standard Edition only.
Enhanced Table Widget
The dashboard/asset page Table widget includes the following enhancements:
"Split-Screen" view: Table widgets display the object/grouping on the left side, and the object data (attributes/metrics) on the right.
Multiple attribute grouping: For Integration data (Kubernetes, ONTAP Advanced Metrics, Docker, etc.), you can choose multiple attributes for grouping. Data is displayed according to the grouping attributes/you choose.
Grouping with Integration Data (shown in Edit mode):
Grouping for Infrastructure data (storage, EC2, VM, ports, etc.) is by a single attribute as before. When grouping by an attribute which is not the object, the table will allow you to expand the group row to see all the objects within the group.
Grouping with Infrastructure data (shown in display mode):
Metrics Filtering
In addition to filtering on an object's attributes in a widget, you can now filter on metrics as well.
When working with integration data (Kubernetes, ONTAP Advanced Data, etc.), metric filtering removes the individual/unmatched data points from the plotted data series, unlike infrastructure data (storage, VM, ports etc.) where filters work on the aggregated value of the data series and potentially remove the entire object from the chart.
ONTAP Advanced Counter Data
Cloud Insights takes advantage of NetApp's ONTAP-specific Advanced Counter Data, which provides a host of counters and metrics collected from ONTAP devices. ONTAP Advanced Counter Data is available to all NetApp ONTAP customers. These metrics enable customized and wide-ranging visualization in Cloud Insights widgets and dashboards.
ONTAP Advanced Counters can be found by searching for "netapp_ontap" in the widget's query, and selecting from among the counters.
You can refine your search by typing additional parts of the counter name. For example:
lif
aggregate
offbox_vscan_server
and more
Please note the following:
Advanced Data collection will be enabled by default for new ONTAP data collectors. To enable Advanced Data collection for your existing ONTAP data collectors, edit the data collector and expand the Advanced Configuration section.
Advanced Data collection is not available for 7-mode ONTAP.
Advanced Counter Dashboards
Cloud Insights comes with a variety of pre-designed dashboards to help get you started on visualizing ONTAP Advanced Counters for topics such as Aggregate Performance, Volume Workload, Processor Activity, and more. If you have at least one ONTAP data collector configured, these can be imported from the Dashboard Gallery on any dashboard list page.
Learn More
More information on ONTAP Advanced Data can be found at the following links:
https://mysupport.netapp.com/site/tools/tool-eula/netapp-harvest (Note: You will need to sign in to NetApp Support)
Policies and Violations Menu
Performance Policies and Violations are now found under the Alerts menu. Policy and Violation functionality are unchanged.
Updated Telegraf Agent
The agent for ingestion of telegraf integration data has been updated to version 1.14, which includes bugs fixes, security fixes, and new plugins.
Note: When configuring a Kubernetes data collector on the Kubernetes platform, you may see an "HTTP status 403 Forbidden" error in the log, due to insufficient permissions in the "clusterrole" attribute.
To work around this issue, add the following highlighted lines to the rules: section of the endpoint-access clusterrole, and then restart the Telegraf pods.
rules: - apiGroups: - "" - apps - autoscaling - batch - extensions - policy - rbac.authorization.k8s.io attributeRestrictions: null resources: - nodes/metrics - nodes/proxy <== Add this line - nodes/stats - pods <== Add this line verbs: - get - list <== Add this line
June 2020
Simplified Data Collector Error Reporting
Reporting a data collector error is easier with the Send Error Report button on the data collector page. Clicking the button sends basic information about the error to NetApp and prompts investigation into the problem. Once pressed, Cloud Insights acknowledges that NetApp has been notified, and the Error Report button is disabled to indicate that an error report for that data collector has been sent. The button remains disabled until the browser page is refreshed.
Widget Improvements
The following improvements have been made in dashboard widgets. These improvements are considered Preview functionality and may not be available for all Cloud Insights environments.
New object/metric chooser: Objects (Storage, Disk, Ports, Nodes, etc.) and their associated metrics (IOPS, Latency, CPU Count, etc.) are now available in widgets in a single inclusive drop-down with powerful search capability. You can enter multiple partial terms in the drop-down, and Cloud Insights will list all object metrics meeting those terms.
Multiple tags grouping: When working with integration data (Kubernetes, etc.), you may group the data by multiple tags/attributes. For example, Sum memory usage by Kubernetes Namespace and Container name.
May 2020
The following roles have been added for Reporting:
Cloud Insights Consumers: can run and view reports
Cloud Insights Authors: can perform the Consumer functions as well as create and manage reports and dashboards
Cloud Insights Administrators: can perform the Author functions as well as all administrative tasks
Cloud Secure Updates
Cloud Insights includes the following recent Cloud Secure changes.
In the Forensics > Activity Forensics page, we provide two views to analyze and investigate user activity:
Activity view, focused on user activity (What operation? Where performed?)
Entities view, focused on what files the user accessed.
Additionally, the Alert email notification now contains a direct link to the alert page.
Dashboard Grouping
Dashboard grouping allows better management of dashboards that are relevant to you. You can add related dashboards to a group for "one-stop" management of, for example, your storage or virtual machines.
Groups are customized per user, so one person's groups can be different from someone else's. You can have as many groups as you need, with as few or as many dashboards in each group as you like.
Dashboard Pinning
You can pin dashboards so favorites always appear at the top of the list.
TV Mode and Auto-Refresh
TV Mode and Auto-Refresh allow for near-real-time display of data on a dashboard or asset page:
TV Mode provides an uncluttered display; the navigation menu is hidden, providing more screen real estate for your data display.
Data in widgets on Dashboards and Asset Landing Pages Auto-Refresh according a refresh interval (as little as every 10 seconds) determined by the Dashboard Time Range selected (or widget time range, if set to override the dashboard time).
Combined, TV Mode and Auto-Refresh provide a live view of your Cloud Insights data, perfect for seamless demonstrations or in-house monitoring.
April 2020
New Dashboard Time Range Choices
Time range choices for dashboards and other Cloud insights pages now include Last 1 Hour and Last 15 Minutes.
Better file and folder metadata change recognition to detect if the user changed Permission, Owner, or Group Ownership.
Export user activity report to CSV.
Cloud Secure monitors and audits all user access operations on files and folders. Activity auditing allows you to comply with internal security policies, meet external compliance requirements such as PCI, GDPR, and HIPAA, and conduct data breach and security incident investigations.
Default Dashboard Time
The default time range for dashboards is now 3 Hours instead of 24 hours.
Optimized Aggregation Times
Optimized time aggregation intervals in time-series widgets (Line, Spline, Area, and Stacked Area charts) are more frequent for 3-hour and 24-hour dashboard/widget time ranges, allowing for faster charting of data.
3 hour time range optimizes to a 1 minute aggregation interval. Previously this was 5 minutes.
24 hour time range optimizes to a 30 minute aggregation interval. Previously this was 1 hour.
You can still override the optimized aggregation by setting a custom interval.
Display Unit Auto-Format
In most widgets, Cloud Insights knows the base unit in which to display values, for example Megabytes, Thousands, Percentage, Milliseconds (ms), etc., and now automatically formats the widget to the most readable unit. For example a data value of 1,234,567,890 bytes would be auto formatted to 1.23 gibibytes. In many cases, Cloud Insights knows the best format for the data being acquired. In cases where the best format is not known, or in widgets where you want to override the automatic formatting, you can choose the format you want.
Import Annotations Using API
With Cloud Insights Premium Edition's powerful API, you can now import annotations and assign them to objects using a .CSV file. You can also import applications and assign business entities in the same way.
Simpler Widget Selector
Adding widgets to dashboards and asset landing pages is easier with a new widget selector that shows all widget types in a single all-at-once view, so the user no longer needs to scroll through a list of widget types to find the one they want to add. Related widgets are color-coordinated and grouped by proximity in the new selector.
February 2020
API with Premium Edition
Cloud Insights Premium Edition comes with a powerful API that can be used to integrate Cloud Insights with other applications, such as CMDB’s or other ticketing systems.
Detailed, Swagger-based information is found in Admin > API Acccess, under the API Documentation link. Swagger provides a brief description and usage information for the API, and allows you to try each API out in your environment.
The Cloud Insights API uses Access Tokens to provide permission-based access to categories of API, such as ASSETS or COLLECTION.
Initial Polling After Adding A Data Collector
Previously, after configuring a new data collector, Cloud Insights would poll the data collector immediately to gather inventory data, but would wait until the configured performance poll interval (typically 15 minutes) to gather initial performance data. It would then wait for another interval before initiating the second performance poll, which meant it would take up to 30 minutes before meaningful data was acquired from a new data collector.
Data collector polling has been greatly improved, such that the initial performance poll occurs immediately after the inventory poll, with the second performance poll occurring within a few seconds after completion of the first performance poll. This allows Cloud Insights to begin showing useful data on dashboards and graphs within a very short time.
This poll behavior also occurs after editing the configuration of an existing data collector.
Easier Widget Duplication
It is easier than ever to create a copy of a widget on a dashboard or landing page. In dashboard Edit mode, click the menu on the widget and select Duplicate. The widget editor is launched, pre-filled with the original widget's configuration and with a “copy” suffix in the widget name. You can easily make any necessary changes and Save the new widget. The widget will be placed at the bottom of your dashboard, and you can position it as needed. Remember to Save your dashboard when all changes are complete.
With Cloud Insights Premium Edition, administrators can enable Single Sign-On (SSO) access to Cloud Insights for all users in their corporate domain, without having to invite them individually. With SSO enabled, any user with the same domain email address can log into Cloud Insights using their corporate credentials.
SSO is only available in Cloud Insights Premium Edition, and must be configured before it can be enabled for Cloud Insights. SSO configuration includes Identity Federation through NetApp Cloud Central. Federation allows single sign-on users to access your NetApp Cloud Central accounts using credentials from your corporate directory. |
January 2020
Swagger documentation for REST API
Swagger explains each available REST API in Cloud Insights, as well as its usage and syntax. Information on Cloud Insights APIs is available in documentation.
Feature Tutorials Progress Bar
The feature tutorials checklist has been moved to the top banner and now features a progress indicator. Tutorials are available for each user until dismissed, and are always available in Cloud Insights documentation.
Acquisition Unit Changes
When installing an Acquisition Unit (AU) on a host or VM that has the same name as an already-installed AU, Cloud Insights assures a unique name by appending the AU name with "_1", "_2", etc. This is also the case when uninstalling and reinstalling an AU from the same VM without first removing it from Cloud Insights. Want a different AU name altogether? No problem; AU's can be renamed after installation.
Optimized Time Aggregation in Widgets
In widgets, you can choose between an Optimized time aggregation interval or a Custom interval that you set. Optimized aggregation automatically selects the right time interval based on the selected dashboard time range (or widget time range, if overriding the dashboard time). The interval dynamically changes as the dashboard or widget time range is changed.
Simplified "Getting Started with Cloud Insights" process
The process for getting started using Cloud Insights has been simplified to make your first-time setup smoother and easier. Simply select an initial data collector and follow the instructions. Cloud Insights will walk you through configuring the data collector and any agent or acquisition unit required. In most cases it will even import one or more initial dashboards so you can start gaining insight into your environment quickly (but please allow up to 30 minutes for Cloud Insights to collect meaningful data).
Additional improvements:
Acquisition Unit installation is simpler and runs faster.
Alphabetical Data Collectors choices make it easier to find the one you’re looking for.
Improved Data Collector setup instructions are easier to follow.
Experienced users can skip the getting started process with the click of a button.
A new Progress bar shows you where you are in the process.
December 2019
Business Entity can be used in filters
Business Entity annotations can be used in filters for queries, widgets, performance policies, and landing pages.
Drill-down available for Single-Value and Gauge widgets, and any widgets rolled to by "All"
Clicking the value in a single-value or gauge widget opens a query page showing the results of the first query used in the widget. Additionally, clicking the legend for any widget whose data is rolled up by "All" will also open a query page showing the results of the first query used in the widget.
Trial period extended
New users who sign up for a free trial of Cloud Insights now have 30 days to evaluate the product. This is an increase from the previous 14-day trial period.
Managed Unit calculation
The calculation of Managed Units (MUs) in Cloud Insights has been changed to the following:
1 Managed Unit = 2 hosts (any virtual or physical machine)
1 Managed Unit = 4 TB of unformatted capacity of physical or virtual disks
This change effectively doubles the environment capacity that you can monitor using your existing Cloud Insights subscription.
November 2019
October 2019
Reporting
Cloud Insights Reporting is a business intelligence tool that enables you to view pre-defined reports or create custom reports. With Reporting you can perform the following tasks:
Run a pre-defined report
Create a custom report
Customize the report format and delivery method
Schedule reports to run automatically
Email reports
Use colors to represent thresholds on data
Cloud Insights Reporting can generate custom reports for areas like chargeback, consumption analysis, and forecasting, and can help answer questions such as the following:
What inventory do I have?
Where is my inventory?
Who is using our assets?
What is the chargeback for allocated storage for a business unit?
How long until I need to acquire additional storage capacity?
Are business units aligned along the proper storage tiers?
How is storage allocation changing over a month, quarter, or year?
Reporting is available with Cloud Insights Premium Edition.
Active IQ Enhancements
Active IQ Risks are now available as objects that can be queried as well as used in dashboard table widgets. The following Risks object attributes are included:
* Category
* Mitigation Category
* Potential Impact
* Risk Detail
* Severity
* Source
* Storage
* Storage Node
* UI Category
September 2019
New Gauge Widgets
Two new widgets are available for displaying single-value data on your dashboards in eye-catching colors based on thresholds you specify. You can display values using either a Solid Gauge or Bullet Gauge. Values that land inside the Warning range are displayed in orange. Values in the Critical range are displayed in red. Values below the Warning threshold are displayed in green.
Conditional Color Formatting for Single Value Widget
You can now display the Single-Value widget with a colored background based on thresholds you set.
Invite Users During Onboarding
At any point during the onboarding process, you can click on Admin > User Management > +User to invite additional users to your Cloud Insights environment. Be aware that users with Guest or User roles will see greater benefit once onboarding is complete and data has been collected.
Data Collector Detail Page improvement
The data collector detail page has been improved to display errors in a more readable format. Errors are now displayed in a separate table on the page, with each error displayed on a separate line in the case of multiple errors for the data collector.
August 2019
All vs. Available Data Collectors
When adding data collectors to your environment, you can set a filter to show only the data collectors available to you based on your subscription level, or all data collectors.
ActiveIQ Integration
Cloud Insights collects data from NetApp ActiveIQ, which provides a series of visualizations, analytics, and other support related services to NetApp customers and their hardware / software systems. Cloud Insights integrates with ONTAP Data Management systems. See Active IQ for more information.
July 2019
Dashboard Improvements
Dashboards and Widgets have been improved with the following changes:
In addition to Sum, Min, Max, and Avg, Count is now an option for roll up in Single-Value widgets. When rolling up by “Count”, Cloud Insights checks if an object is active or not, and only adds the active ones to the count. The resulting number is subject to aggregation and filters.
In the Single-Value widget, you now have a choice to display the resulting number with 0, 1, 2, 3, or 4 decimal places.
Line charts show an axis label and units when a single counter is being plotted.
Transform option is available for Services integration data now in all time-series widgets for all metrics. For any services integration (Telegraf) counter or metric in time-series widgets (Line, Spline, Area, Stacked Area), you are given a choice of how you want to Transform the values. None (display value as-is), Sum, Delta, Cumulative, etc.
Downgrading to Basic Edition
Downgrade to Basic Edition fails with an error message if there is no available NetApp device configured that has successfully completed a poll in the last 7 days.
Collecting Kube-State-Metrics
The Kubernetes Data Collector now collects objects and counters from the kube-state-metrics plugin, greatly expanding the number and scope of metrics available for monitoring in Cloud Insights.
June 2019
Cloud Insights Editions
Cloud Insights is available in different Editions to fit your budget and business needs. Existing NetApp customers with an active NetApp support account can enjoy 7 days of data retention and access to NetApp data collectors with the free Basic Edition, or get increased data retention, access to all supported data collectors, expert technical support and more with Standard Edition. For more information on available features, see NetApp's Cloud Insights site.
New Infrastructure Data Collector: NetApp HCI
NetApp HCI Virtual Center has been added as an Infrastructure data collector. The HCI Virtual Center data collector collects NetApp HCI Host information and requires read-only privileges on all objects within the Virtual Center.
Note that the HCI data collector acquires from the HCI Virtual Center only. To collect data from the storage system, you must also configure the NetApp SolidFire data collector.
May 2019
New Service Data Collector: Kapacitor
Kapacitor has been added as a data collector for services.
Integration with Services via Telegraf
In addition to acquisition of data from infrastructure devices such as switches and storage, Cloud Insights now collects data from a variety of Operating Systems and Services, using Telegraf as its agent for collection of integration data. Telegraf is a plugin-driven agent that can be used to collect and report metrics. Input plugins are used to collect the desired information into the agent by accessing the system/OS directly, by calling third-party APIs, or by listening to configured streams.
Documentation for currently supported integrations can be found in the menu to the left under Reference and Support.
Storage Virtual Machine Assets
Storage Virtual Machines (SVMs) are available as assets in Cloud Insights. SVMs have their own Asset Landing Pages, and can be displayed and used in searches, queries, and filters. SVMs can also be used in dashboard widgets as well as associated with annotations.
Reduced Acquisition Unit System Requirements
The system CPU and memory requirements for the Acquisition Unit (AU) software have been reduced. The new requirements are:
Component |
Old Requirement |
New Requirement |
CPU Cores |
4 |
2 |
Memory |
16 GB |
8 GB |
Additional Platforms Supported
The following platforms have been added to those currently supported for Cloud Insights:
Linux |
Windows |
CentOS 7.3 64-bit |
Microsoft Windows 10 64-bit |
April 2019
Filter Virtual Machines by Tags
When configuring the following data collectors, you can filter to include or exclude virtual machines from data collection according to their Tags or Labels.
March 2019
Email Notifications for Subscription-related Events
You can select recipients for email notifications when subscription-related events occur, such as upcoming trial expiration or subscribed account changes. You can choose recipients for these notifications from among following:
All Account Owners
All Administrators
Additional Email Addresses that you specify
The following new AWS-focused dashboards have been added to the gallery and are available for import:
AWS Admin - Which EC2 are in high demand?
AWS EC2 Instance Performance by Region
February 2019
Collecting from AWS Child Accounts
Cloud Insights supports collection from AWS child accounts within a single data collector. Your AWS environment must be configured to allow Cloud Insights to collect from child accounts.
Data Collector Naming
Data Collector names can now include periods (.), hyphens (-), and spaces ( ) in addition to letters, numbers, and underscores. Names may not begin or end with a space, period, or hyphen.
Acquisition Unit for Windows
You can configure a Cloud Insights Acquisition Unit on a Windows server/VM. Review the Windows pre-requisites before installing the Acquisition Unit software.
January 2019
"Owner" field is more readable
In Dashboard and Query lists, the data for the "Owner" field was previously an authorization ID string, instead of a user-friendly owner name. The "Owner" field now shows a simpler and more readable owner name.
Managed Unit Breakdown on Subscription Page
For each data collector listed on the Admin > Subscription page, you can now see a breakdown of Managed Unit (MU) counts for hosts and storage, as well as the total.
December 2018
Improvement of UI Load Time
The initial loading time for the Cloud Insights user interface (UI) has been significantly improved. Refresh time for the UI also benefits from this improvement in circumstances where metadata is loaded.
Bulk Edit Data Collectors
You can edit information for multiple data collectors at the same time. On the Observability > Collectors page, select the data collectors to modify by checking the box to the left of each and click the Bulk Actions button. Choose Edit and modify the necessary fields.
The data collectors selected must be the same vendor and model, and reside on the same Acquisition Unit.
Support and Subscription pages are Available During Onboarding
During the onboarding workflow, you can navigate to the Help > Support and Admin > Subscription pages. Returning from those pages returns you to the onboarding workflow, providing you have not closed the browser tab.
November 2018
Subscribe through NetApp Sales or AWS Marketplace
Cloud Insights subscription and billing is now available directly through NetApp. This is in addition to the self-serve subscription available through AWS Marketplace. A new Contact Sales link is presented on the Admin > Subscription page. For customers whose environments have or are expected to have 1,000 or more Managed Units (MUs), it is recommended to contact NetApp sales via the Contact Sales link.
Text Annotation Hyperlinks
Text-type annotations can now include hyperlinks.
Onboarding Walkthrough
Cloud Insights now features an onboarding walkthrough for the first user (administrator or account owner) to log in to a new environment. The walkthrough takes you through installing an Acquisition Unit, configuring an initial data collector, and selecting one or more useful dashboards.
Import Dashboards from the Gallery
In addition to selecting dashboards during onboarding, you can import dashboards via Dashboards > Show All Dashboards and clicking +From Gallery.
Duplicating Dashboards
The ability to duplicate a dashboard has been added to the dashboard list page as a choice in the options menu for each dashboard, and on a dashboard's main page itself from the Save menu.
Cloud Central products menu
The menu allowing you to switch to other NetApp Cloud Central products has moved to the upper right corner of the screen.
