What's new in NetApp virtualization solutions
Learn what's new in virtualization solutions.
5 November 2026
Added guidance to keep NFS v4.2 sparse file operations disabled for Proxmox VE NFS storage.
22 October 2026
Added the recommended ONTAP OS type for NVMe namespaces, NVMe subsystems, LUNs, and igroups used with Proxmox VE.
Provision ONTAP storage for Proxmox Virtual Environment == 14 October 2026
Added business continuity solution for Proxmox VE with ONTAP SnapMirror active sync.
Learn about Proxmox VE business continuity with SnapMirror active sync
Learn how a Proxmox VE stretch cluster with SnapMirror active sync for NAS keeps VMs running through a storage or site failure with zero RPO. Includes corosync and QDevice design considerations, ONTAP Mediator and ONTAP Cloud Mediator options, VIP LIFs with BGP for layer 3 networks, and a comparison with MetroCluster.
Configure Proxmox VE business continuity with NAS storage
Configure the mediator, protect the NFS SVM, build the stretch cluster with a QDevice, provision NFS shared storage, and set up HA and VM backups with Storage Manager for Proxmox.
21 August 2026
Updated VCF documentation to reflect VCF 9.1 release and ONTAP 9.19.1 features.
10 May 2026
Added End User Computing (EUC) solutions for NetApp ONTAP.
15 January 2026
Updated Proxmox VE solution contents to reflect Proxmox VE 9 release.
Added instructions to enable Anti-Ransomware protection on volumes used for Proxmox VE storage.
Added instructions to use FC and NVMe/FC as storage protocol for Proxmox VE.
Added ONTAP integration for Proxmox Backup Server.
Added deployment guidelines for ONTAP integration with Proxmox VE.
12 November 2025
Provided the correct download links for the NetApp Shift Toolkit
Added migration solutions for NetApp Shift Toolkit
18 August 2025
The NetApp Solutions site is now the NetApp solutions family, which includes the following sites:
