• MetroCluster release notes
  • Install a fabric-attached MetroCluster
    • Prepare for the MetroCluster installation
    • Cable a fabric-attached MetroCluster configuration
      • Parts of a fabric MetroCluster configuration
      • Install and cable MetroCluster components
        • Port assignments for FC switches
      • Configure the FC switches
        • Configure Brocade FC switches with RCF files
        • Configure the Cisco FC switches with RCF files
    • How to use the Active IQ Unified Manager and ONTAP System Manager for further configuration and monitoring
  • Install a MetroCluster IP configuration
      • ISL requirements
      • Considerations for using MetroCluster-compliant switches
    • Configure the MetroCluster hardware components
      • Cable the MetroCluster IP switches
      • Configure the MetroCluster IP switches
        • Configure Cisco IP switches
        • Configure NVIDIA IP switches
      • Monitor MetroCluster IP switch health
    • Configure the MetroCluster software in ONTAP
      • Configure the MetroCluster software using the CLI
      • Configure the MetroCluster software using System Manager
    • Configure ONTAP Mediator for unplanned automatic switchover
  • Install a stretch MetroCluster configuration
    • Cable a two-node SAS-attached stretch MetroCluster configuration
      • Install and cable MetroCluster components for two-node SAS-attached stretch configurations
    • Cable a two-node bridge-attached stretch MetroCluster configuration
  • Install and configure MetroCluster Tiebreaker
    • Install the Tiebreaker software
      • Install the Tiebreaker software package
        • Install Tiebreaker 1.5
        • Install Tiebreaker 1.4
  • Understand MetroCluster data protection and disaster recovery
  • Perform switchover, healing, and switchback
    • Perform switchover for tests or maintenance
      • Heal the configuration
        • Heal the configuration in a MetroCluster FC configuration
  • Maintain the MetroCluster components
    • Prepare for MetroCluster maintenance
    • Maintenance procedures for MetroCluster FC configurations
      • FC-to-SAS bridge maintenance
      • FC switch maintenance and replacement
      • Hot add storage to a MetroCluster FC configuration
        • Hot add SAS storage to a bridge-attached MetroCluster FC configuration
    • Maintenance procedures for MetroCluster IP configurations
      • IP switch maintenance and replacement
    • Maintenance procedures for all MetroCluster configurations
  • Transition from MetroCluster FC to MetroCluster IP
    • Transition nondisruptively from a MetroCluster FC to a MetroCluster IP configuration (ONTAP 9.8 and later)
      • Prepare for transition from a MetroCluster FC to a MetroCluster IP configuration
      • Transition from MetroCluster FC to MetroCluster IP configurations
    • Disruptively transition from a two-node MetroCluster FC to a four-node MetroCluster IP configuration (ONTAP 9.8 and later)
  • Upgrade, refresh, or expand the MetroCluster configuration
    • Start here - Choose your procedure
    • Upgrade controllers in four-node MetroCluster IP using switchover and switchback with "system controller replace" commands (ONTAP 9.13.1 and later)
      • Prepare to upgrade
      • Upgrade your controllers
    • Upgrade controllers in MetroCluster IP using switchover and switchback (ONTAP 9.8 and later)
    • Expand a two-node MetroCluster FC configuration to a four-node configuration
      • Add a new controller module to each cluster
        • Install and cable the new controller module
    • Expand a four-node MetroCluster FC configuration to an eight-node configuration
      • Recable and zone a switch fabric for the new nodes
      • Configure ONTAP on the new controllers
        • Configure the clusters into a MetroCluster configuration
  • Recover from a disaster
    • Recover from a multi-controller or storage failure
      • Prepare for switchback in a MetroCluster IP configuration
      • Prepare for switchback in a MetroCluster FC configuration
