Delete a consistency group
Deletes a consistency group. This action removes the group itself but leaves associated volumes or LUNs intact, which you can manage separately using their respective endpoints.
HTTP method and endpoint
DELETE /application/consistency-groups/{uuid}
Introduced in
ONTAP 9.10
Usage notes
this will not delete any associated volumes or LUNs. To remove those elements, you can use the appropriate object endpoint. |
Related ONTAP commands
There are no ONTAP commands for managing consistency groups.
uuid |
string |
path |
True |
The unique identifier of the consistency group to delete. |
delete_data |
boolean |
query |
False |
Delete the underlying storage as well as the consistency group association. This parameter should be used with caution.
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53411842 |
Consistency group does not exist. |
53411843 |
A consistency group with specified UUID was not found. |
53411844 |
Specified consistency group was not found in the specified SVM. |
53411845 |
The specified UUID and name refer to different consistency groups. |
53411846 |
Either name or UUID must be provided. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
