REST API reference
Delete a consistency group
DELETE /application/consistency-groups/{uuid}
Introduced In: 9.10
Deletes a consistency group.
Note this will not delete any associated volumes or LUNs. To delete those elements, use the appropriate object endpoint.
  • vserver consistency-group delete
uuid
string
path
True
The unique identifier of the consistency group to delete.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
53411842
Consistency group does not exist.
53411843
A consistency group with specified UUID was not found.
53411844
Specified consistency group was not found in the specified SVM.
53411845
The specified UUID and name refer to different consistency groups.
53411846
Either name or UUID must be provided.
53412041
Cannot delete a consistency group because it contains one or more storage units that are part of replication relationships.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
