Delete a consistency group
Deletes a consistency group without affecting any associated volumes or LUNs. Use this operation when you need to manage your data protection strategy by removing unneeded consistency groups.
HTTP method and endpoint
DELETE /application/consistency-groups/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Deletes a consistency group.
this will not delete any associated volumes or LUNs. To remove those elements, you can use the appropriate object endpoint. |
Related ONTAP commands
There are no ONTAP commands for managing consistency groups.
uuid |
string |
path |
True |
The unique identifier of the consistency group to delete. |
delete_data |
boolean |
query |
False |
Delete the underlying storage as well as the consistency group association. This parameter should be used with caution.
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53411842 |
Consistency group does not exist. |
53411843 |
A consistency group with specified UUID was not found. |
53411844 |
Specified consistency group was not found in the specified SVM. |
53411845 |
The specified UUID and name refer to different consistency groups. |
53411846 |
Either name or UUID must be provided. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
