REST API reference
Delete a consistency group
Deletes a consistency group to remove it from the system. This operation does not affect any associated volumes or LUNs, which must be deleted separately.
HTTP method and endpoint
DELETE /application/consistency-groups/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Note this will not delete any associated volumes or LUNs. To delete those elements, use the appropriate object endpoint.
There are no ONTAP commands for managing consistency groups.
uuid
string
path
True
The unique identifier of the consistency group to delete.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
53411842
Consistency group does not exist.
53411843
A consistency group with specified UUID was not found.
53411844
Specified consistency group was not found in the specified SVM.
53411845
The specified UUID and name refer to different consistency groups.
53411846
Either name or UUID must be provided.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
