REST API reference
Delete a consistency group
Deletes a consistency group to remove its definition from the system while keeping associated volumes or LUNs intact for separate management.
HTTP method and endpoint
DELETE /application/consistency-groups/{uuid}
Introduced in
ONTAP 9.10
Usage notes
Note this will not delete any associated volumes or LUNs. To remove those elements, you can use the appropriate object endpoint.
There are no ONTAP commands for managing consistency groups.
uuid
string
path
True
The unique identifier of the consistency group to delete.
delete_data
boolean
query
False
Delete the underlying storage as well as the consistency group association. This parameter should be used with caution.
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
53411842
Consistency group does not exist.
53411843
A consistency group with specified UUID was not found.
53411844
Specified consistency group was not found in the specified SVM.
53411845
The specified UUID and name refer to different consistency groups.
53411846
Either name or UUID must be provided.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
