Delete a consistency group
DELETE /application/consistency-groups/{uuid}
Introduced In: 9.10
Deletes a consistency group.
this will not delete any associated volumes or LUNs. To delete those elements, use the appropriate object endpoint. |
Related ONTAP commands
There are no ONTAP commands for managing consistency groups.
uuid |
string |
path |
True |
The unique identifier of the consistency group to delete. |
return_timeout |
integer |
query |
False |
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53411842 |
Consistency group does not exist. |
53411843 |
A consistency group with specified UUID was not found. |
53411844 |
Specified consistency group was not found in the specified SVM. |
53411845 |
The specified UUID and name refer to different consistency groups. |
53411846 |
Either name or UUID must be provided. |
53412041 |
Cannot delete a consistency group because it contains one or more storage units that are part of replication relationships. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
