REST API reference
Clear suspect files of a volume
Clears suspect files from a volume, either targeting all suspect files or specifying them based on file format or suspect time.
HTTP method and endpoint
DELETE /security/anti-ransomware/suspects/{volume.uuid}
Introduced in
ONTAP 9.10
Usage notes
Clears either all the suspect files of a volume or suspect files of a volume based on file format or suspect time provided.
  • security anti-ransomware volume attack clear-suspect
volume.uuid
string
path
True
Identification of the Anti-ransomware suspect file for the deletion.
  • format: uuid
return_records
boolean
query
False
  • Default value:
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
        "href": "/api/resourcelink"
    "uuid": "string"
string
self
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
